My R32 Gtr
PSI_GTSII
 Share
Looks Mint!
I always wanted a Black R32 GTR, but I settled for a Gun Metal Grey one and still liking it as I realise Black and Grey look really Tuff!
How did you got about modifing the front Brake Calipers to Ferrari F50 Brembos?
Straight bolt on or you had to modify afew things in order to fit them on?
I imported this 3 years ago now from Japan, apart from the 34 GTR rims, a Jasma cat back exhaust it was pretty well standard, $20'000 licensed and complied.
Since then I have added:
GT2560r Turbos
Trust / Greddy Front and Dump Pipes
PFC (Non D-Jetro)
Nismo fuel pressure reg
Apexi Air Filters
HKS Kansai Strut brace
Trust Oil Filter relocation kit
Brembo F50 355mm Brakes
Extreme 6 Puck button clutch
HKS Hipermax III Coilovers
Federal 595RS Tyres
Momo Steering Wheel
Momo Gearknob
Sparco Sprint V seats
Full interior retrim to Match front seats
Dentcraft removed all body imperfections, now perfectly straight
As far as GTRs go it is fairly mildly modified.
Produces 400rwHP @ 18psi
Runs an 11.9 @ 117mph 1.793 60ft
Ran a 58.9 around Barbagello (short) in the wet
Only travelled 8000kms in 3 years, odo now showing 77'000kms.
Very happy with it, the only thing to go wrong has been a Water pump which proceded to put the fan thru the radiator, but was cheap enough to fix (Under $500)
Bullcreek Avaition Museum
Nissan Flag
Work Depot
New 'Sparco' themed interior
R34 Themed Engine bay
Brembo F50 Brakes 355mm
Paintless dent removal did an amazing job, removed all small dents, car perfectly straight!
Really nice ride mate... I recently bought myself a Gtr and the 32 is the best shape.. Cheers... :blink:
I was going to say 'nice', but will think of another word for obvious reasons.
'cool' seems apropriate because you have ended up with a car that doesn't go over the top with 'extras'.
I like that you have not gone overboard with the height [looks standard], I reckon GTRs look better at, or about factory height.
anyway, I reckon this is one of the best looking 32s I've seen on here.
did you say what the mods cost?.
 Share
    • Greetings to you all, It's an honour to be part of the great forum. I’m happy to learn and build good  relationships with members of this community. Thanks for having me!
    • normally i don't like to get involed with these kinds of self promotions stuff, but good on you for living your dream man.
    • Remember our cars are 30+ years old so expect the rubber bits to leak. I'd go around your engine bay with a can of "start ya bastard" or similar and look for leaks. FYI I got my car 10+ years ago with the standard boost restrictor in place, I removed it when I got it and the car never had any issues since (besices a leaking manifold gasket). tl;dr- Look for leaks before proceeding.
    • That SSR is actually the same (or similar) as the Jaycar 100AMP SSR (which I use). They suggest the resistor to stop the SSR turning on when the ECU turns off (I believe). I personally don't use the resistor as I use the 5V output from the ECU to supply power to the SSR. I do however run a flyback diode, the old Haltech documentation was wrong too and didn't specify the fly back, I mentioned it to a few of their staff and they eventually added it in.
    • I did manage to do this without removing the engine or front cross member, but I had the advantage that the exhaust manifold was removed. I am not setup to support the engine from the top or remove it. 1. Loosen the engine mount nuts so they only have a nut of thread. If it is a manual, I think you have to remove the gearbox to engine support brackets. 2. Jack up the engine off the bottom idler mount. Jack it up till the end of the slot and nut on the mount. You need this clearance to get the pan out at the rear of the engine. 3.Break the sealant seal to sump. I found a oil pan separator tool helpful to get it started. 4. The oil pick up can be removed with the gap available.  5. The oil pan can be removed now. 6. Before assembling, do not apply sealant to the oil pick up area as your hand will rub it all off but apply to the other three and a bit sides. 7. It is a two man job to put the oil pan back, with the sealant, as you do not want it to touch anything and rub off. 8. With one person supporting the oil pan the other can fit the oil pickup 9. Apply the remaining sealant. This would be more difficult with the manifold or turbo in place, but I think it could be done. As you can see my sealant is a bit ugly, but good enough to seal. 10. Lift the sump up to the engine and bolt it on. We found it was easier to use two long guide bolts at each end to get it nice and aligned without touching.
