  • Replies 166
Originally posted by EnricoPalazzo
hey maxx, thanks for letting me in front of u in the car park :D Man that red JMS r33 ****en rocks
no worry mate;) nice to meet u anyway! yr car looks very good!
i was so impressed by ken's car, the speed & movement are just great,(need to smoke the tyre more though) not even a 200+kw silvia can compare, gtr are the best!
:uh-huh: :burnout:
JJ one it again, was a dood day apart from the rain Has anyone thought bout getting a skyline australia banner mad up? it would be good for thinghs like that, everyone would be able to find everyone else. would only cost bout 5-10 each. any ideas??
Cheers Matt
Hey Dean did you leave about 12:30 or so? , I saw a car the same as yours leaving as I was coming in (just past the canteen), ....wasnt sure if it was u?.. I was in my black spec II with g/f in the passenger side.
I saw your car there Maxx , and I saw Nightcrawler leaving.. only stayed about 30 mins as the weather was wrong.
Oh yeah and saw some 4x4's driving on the salt lake next door ...was pretty cool.
Yeah we were sick of the wind and rain so left at about 12:30pm .... spewin we missed Miss33 and Dean - was good to see Chapman and the rest of the blokes around the barbie - mighty fine tent we made there - did it weather the storm after we left? :wave:
BOOSTD and I only saw a few of you guys, we couldn't even find where you guys were having the bbq!
Saw Dean, Erica and Munro but I don't think anyone really hung around after it started pouring!! The weather did clear towards the end of the day though!!
I definately got my five bucks worth !!!! hang on Miss*33 paid for me. Anyway I would have paid $5 for every lap the JMS 33 did, as Timmmmaaayyy would say "Orgasmic". Pitty the Pirelli tyres he used I was looking at putting on my car. Owell not sure how 285's would go under my guards anyway.....
Didn't see any police on the way out. In contrast to Friday night....hooly dooly
Police blocked us in at Harndorf Oval. Luckly they let us go, maybe from some persuasion from a certain WRX owner who also wears a blue suit. After that we were greeted at almost every other regroup by the boys in blue. Also got lost again and again.
I had fun tho, sat with Munro's 34 most of the night.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
