BOZ22N Posted February 21, 2008 Share Posted February 21, 2008 Hi, As the title says I am trying to choose a sway bar combination. I have been looking at SK's group buy whiteline stuff and noticed that the adj sway bars are 24mm front and rear. On greenline’s website the nismo ones are non-adjustable and are 27mm front and 23mm rear. I don’t mind the rear being a little softer but is 27mm at the front just too big? Would you be able to adjust a 24mm bar to be as tight as a 27mm one? My car is a R33 GTS-T which is trying to be a track car (well one day, eventually, maybe ) Anyone with some first hand experience would be great. Cheers, Ryan Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/ Share on other sites More sharing options...
BOZ22N Posted February 21, 2008 Author Share Posted February 21, 2008 just found this. http://www.skylinesaustralia.com/forums/Sw...=nismo+swaybars If i read it right the whiteline front adjustable ones will be as stiff as a nismo one when adjusted all the way across? And visa versa with the rear? Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3663715 Share on other sites More sharing options...
MrStabby Posted February 21, 2008 Share Posted February 21, 2008 If you're going to track it the ability to tune front/rear roll stiffness (which will help you balance understeer/oversteer) will be pretty useful. I'd go for the whileline adjustables. Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3664337 Share on other sites More sharing options...
Kaido_RR Posted February 21, 2008 Share Posted February 21, 2008 im running nismo swaybars in my r33 gtst, it works perfect with my setup Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3664355 Share on other sites More sharing options...
Ant97GTR Posted February 21, 2008 Share Posted February 21, 2008 Mate there is little point getting a Nismo one as the locally produced ones are just as good. Plus if you are going to track it def go the adj ones as you can easily tune your setup to suit the track on the day. Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3665767 Share on other sites More sharing options...
BOZ22N Posted February 22, 2008 Author Share Posted February 22, 2008 thanks guys i think i will go whiteline ones. Cheers, Ryan Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3666870 Share on other sites More sharing options...
Sydneykid Posted February 22, 2008 Share Posted February 22, 2008 thanks guys i think i will go whiteline ones.Cheers, Ryan Try the Group Buy section. Cheers Gary Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3668317 Share on other sites More sharing options...
Trust33 Posted February 23, 2008 Share Posted February 23, 2008 good luck getting the whiteline front swaybar link set on full hard. the bar will only adjust to 3rd and 2nd hole consecutivly. unless i guess if u got some other kind of linkage. Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3668954 Share on other sites More sharing options...
Trust33 Posted February 23, 2008 Share Posted February 23, 2008 sk how do i attain full hard setting? Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3668972 Share on other sites More sharing options...
SevenAngryPenguins Posted February 23, 2008 Share Posted February 23, 2008 you sure it was that hard... i got mine into the second hardest hole no problems at all Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3669128 Share on other sites More sharing options...
Trust33 Posted February 23, 2008 Share Posted February 23, 2008 how? maybe im not trying hard enough. Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3669274 Share on other sites More sharing options...
Duncan Posted February 23, 2008 Share Posted February 23, 2008 whatchya mean craig? couldn't get the link down to the last holes or were you worried about the angle once you got it there. or does it foul on something? the trick to installing sway bar is that the car has to be level left to right both front and rear when you try and fit it, otherwise the sway bar does exactly what it is designed to do - put pressure on the opposite side. If you cant get the car level jack under the lower wheel until it is level, then the bar will fit fine. Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3669560 Share on other sites More sharing options...
PT Posted February 24, 2008 Share Posted February 24, 2008 nismo sway bars are hollow (most jap sways are) and a lot lighter than the whiteline bars but whiteline do have the advantage of being adjustable unlike the nismo's Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3669856 Share on other sites More sharing options...
SevenAngryPenguins Posted February 24, 2008 Share Posted February 24, 2008 how? maybe im not trying hard enough. put the car up on wheel ramps and the just pushed the link into the whole i wanted Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3671382 Share on other sites More sharing options...
ZENNON Posted February 24, 2008 Share Posted February 24, 2008 put the car up on wheel ramps and the just pushed the link into the whole i wanted You can do 45 push-ups in 30seconds though.... Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3671448 Share on other sites More sharing options...
Sydneykid Posted February 25, 2008 Share Posted February 25, 2008 sk how do i attain full hard setting? Swap the link to the front of the upright/hub. Cheers Gary Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3672010 Share on other sites More sharing options...
SevenAngryPenguins Posted February 25, 2008 Share Posted February 25, 2008 You can do 45 push-ups in 30seconds though.... i knew i would regret telling you that Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3673185 Share on other sites More sharing options...
Trust33 Posted February 25, 2008 Share Posted February 25, 2008 cheers fellas. when im down south i will give it a go. Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3673973 Share on other sites More sharing options...
Trust33 Posted February 25, 2008 Share Posted February 25, 2008 whatchya mean craig? couldn't get the link down to the last holes or were you worried about the angle once you got it there. or does it foul on something?the trick to installing sway bar is that the car has to be level left to right both front and rear when you try and fit it, otherwise the sway bar does exactly what it is designed to do - put pressure on the opposite side. If you cant get the car level jack under the lower wheel until it is level, then the bar will fit fine. it doesnt foul on anything. as far as i can remember, and i do remember the angle it was sittiing at was a bit disturbing, it was installed a long time ago, it was giving me shit trying to get it any harder than that setting. but i have never tried installing it with all 4 wheels off the ground. still i dont see what difference it will make by doing that. to me, driving the car up onto ramps sounds like it could work. Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3674015 Share on other sites More sharing options...
bumble_bee Posted March 4, 2008 Share Posted March 4, 2008 hey,have u got p/n's for the whiteline bars? mit look into it too, coz my bushes are gone on my front sway.. so mit aswell upgrade the bar and will changing the bushes too... Link to comment https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/#findComment-3694698 Share on other sites More sharing options...
