PFC for sale in the parts section. What you think? $850 ono, 2nd hand, with controller, works fine etc. Worth making an offer for? how often do these come up?
worth checking out, contact the seller and get more info, if possible go look, if in good working order offer a bit less, he might drop the price, these items while still available are getting harder to source, traders still seem to be able to get new ones, that price is pretty reasonable(if in good nick) but it's horses for courses if you can afford a new one and don't mind a bit of a wait contact a trader in the trader section( he might have one available)
good hunting
leetom.
  • 1 month later...
  • Replies 104
Picked up a PFC w/ Cont. from Blitz (nick). Sounds like it is a logcal step in the mod process. Will now try and track down a Power FC boost controller - i dont think these are vehicle specific so shouldnt be too difficult. Or would a bleed valve be sufficient?
Has anyone had any good experiences with workshops that youd recommend i go to for a tune? Also, filterwise, is it worth spending the extra dosh on big brands? what do you use, and what works well?
I would run an EBC over a bleed valve, dont wana risk damaging the motor. The PFC boost controls are very good, only way to access the boost level is through the hand controller though.
Filter wise yes, spend the extra, the cheap ones either flow nuthing, block easily or worst case can be sucked in. ANy good jap brand is ok, have had a few mates use the apexi ones which bolt straight onto the afm.
Tune wise im not sure, all my work is getting done at Gavin Wood Autotech they seem pretty switched on and i belive they just got a dyno?
Bobby: I run a AVC-R with no worries at all, AND I get the benefit of having a hi and lo boost setting accessible with a couple of button presses... Considered the PFC boos controller, but I didn't want a great dirty hand controller hanging off the dash whenever I went driving...
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
