Friday 22nd Feb Queensland Raceway Drift Practice
Hi just lettin anyone know that doesent that drift practice is on tomorrow night fri the 22nd at archerfield gates open at 5 you need long clothes and an dot approved helmet and about 120 i think it is if you have no licence. Im heading out there for my first time not sure how i will go but i will let u know. For those that dont know QR is next to willowbank, see ya'll there ill be in the grey 33!
Peace lars
I'll be there sliding around :D Black r33 [RBR33] If anyone wants to say hello.
Josh is gonna be there as well with his r32 with fresh paint! thing looks f*king sick :)
Might wanna add that it's $10 entry at the gate for anyone going to spectate.
Sorry kody i thought u knew about it. Yeah ill be there for sure.
It was nice to meet u too tiff.
Oh and damn its hard to drift QR with std suspension and not enough power.
Edited by Nissan-r33
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
