  blakey1804 said:
I just got my first skyline today Black '96 r33 GTS-T, i was just wondering what is the best fuel to use in it? Its all stock atm and the last guy was using 98 octain BP ultimate. Thx
BP ultimate
congratulations and welcome! im sure everyone will agree, only use 98 octane, i use shell 99% of the time and caltex is next in line. my mechanic said that they are all pretty much the same but where possible use the same pump at the same servo all the time.
post up some pics for everyone to see
  gtrzilla said:
+1 BP ultimate
ive used the Vpower ethanol 100 stuff couple of times but dont really trust it :rofl:
How is that stuff anyway? Does that extra 2 Octane make any difference?
I stick to BP as advised by my mechanic.
Also different fuel companies have different additives in their 98 Octane. SO personal choice / ppls experiance.
I go BP > Mobil > Caltex > Shell... IMO
^^ Friend told me he used it (100 Octane) he did not notice anything compaired to 98 Octane.
Plus Our cars would have had to be tuned for AUS fuel and I guess at the time 98 was pretty much the highest, when I bought my car.
100 only came out early last year from memory but was probley avaliable at selected Shell stations prier to all.
Edited by (00)SKYLINE(00)
+ 1 to bp ultimate..
I think its best to stick to this fuel... as most skyline drivers use it.
Although whatever you choose to use, i think its best to stick with it and continue to use the same fuel, as said by someone above. Swapping between fuels all the time i personally dont think is good for your car...
  HKS_R34 said:
Congrats on the pick up. Definatly only use bp ulitmate. Dont stinge out on fuel.
LOL! Funny you say that, I saw a guy filling up his Ferrari 360 Spyder at 7 Eleven.
I wouldn't even put that stuff in my Mitsubishi Lancer GLi.
lol, im not sure if this is true, as it was on aca or tt... but they said that all the fuel that is in these bowsers, comes from the same production plant.
so it wont make a difference what BRAND it is, just what ron rating it is.
lol, if anyone knows if the petrol thing is false, please correct me...i did hear is on aca/tt after all:S
Always used bp ultimate in my skylines but have been trying shell racing Vpower 100 fuel for the last couple of months.
Dont know if i like it. Cant feel any difference.
Going back to BP Ultimate though!!
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
