if im not in a hurry i normally wait for the oil pressure to hit normal. most morning id run out side start the car up set the turbo timer to 10 mins then arm the alarm and run back in lol by the time im dressed shes nice and warm and good to go. if im in a hurry id get it wait for 1 min start driving but wont hit boost and like others say keep revs below 3000rpm
idle ur car is bad for ur engine? cant be??
Idling is not bad for your motor. Running cold is.
So (within reason) the quicker it gets up to its correct operating temperature the less wear you will get.
So sitting in the driveway for 5 minutes whilst the thing sits there running cold is bad for the motor & will undoubtedly annoy the fk out of your neighbours.
i agree, on a cold morning just letting the car sit and idle till it warms up can take much much longer than if you just drive it slow, especially if the car doesn't get kept in a closed off garage.
and also the time it takes depends on your thermostat. if your thermostat is stuffed and not closing properly, letting it idle up to temp could take an hour on a very cold morning, which isn't good for the motor at all.
when i drive to work in the morning, by the time i have been sitting at intersections, etc, the car is usually up to temp in less than 1km, and that would be no more than 3 or 4 mins. although my skyline used to take a touch longer to come up to temp.
Yeah it's a trade off between running your car cold on idle for 5mins, or driving your car cold under 3000rpm for 2mins...
Personally i drive below 3000rpm to warm mine up... and never put my foot into it until the oil temp has got above 70.
yep, very bad idea to let the car sit at cold idling for 5 mins. apart from being bad for the engine it also means that you are not getting any temp into your gearbox, diffs, brakes or clutch. so when you do finally set off your engine will be up to temp but nothing else will be.
imo the best idea is start car. take your time getting comfy etc and you should be edging out of the garage about 30 seconds after you started the car. I am the same as ferni in that I just drive it normally along (minimal boost, revs under about 3,000) until the oil temp passes 70. then you can have some fun if you want, but hold off on any real 'fangining' until oil temp is 75+. :thumbsup:
remote start while i'm brushing my teeth...
when i get in a minute later the climate control is just right, dvd is playing, cars starting to get warm and the back windscreen is demisted.
/bling
It's even more important to warm the car a little if you're running forged pistons. I usually finish breakfast, start car, brush teeth then drive away below 3k with gentle acceleration.
I read somewhere that 90% of engine wear occurs in the first 11 mins, how true this is im not sure. But judging by how much longer oil temp takes to increase compared to water temp its certainly increased my level of engine sympathy from now on...
Driving at below 300rpm may be fine for a gtst, because it wont be on boost, but for a gtr (a standard one that is) it is on boost. My car has forged pistons and I find that it wont rev really well because of co;d start requirements anyway. What I do is let it sit there for a couple of minutes till say the water temp guage reads at about 1/4 then begin to drive it, gently of course until fully warmed up. The oil temp guage in the centre, i think this is for the gearbox, will take about three times as long to warm up as your engine, but still be carefull with it until it reaches about 85 degrees.
Hope this helped.
how much it comes on boost depends on how much accelerator you give it. my gts-t would be at 13psi by less than 3000rpm if i booted it, but i could keep it pretty much off boost and drive along at 4000rpm. the more you plant your foot the more boost you are going to give it. not just the rpm.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
