Hey guyz anyone got pics of R33's with LED tail lights and where could i find them, i aint looking for the dicky chrome ones..
Thanks
Chris
eBay perhaps?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=200200461403?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=110225877433?
I saw something like that but instead of the chrome it was the same color as the car?
Look closer @ it, im pretty sure this is how u buy all of them for Skylines. Look at how the chrome aint flush with the light.
After u buy them, u take the shell/surround of the stock lights and put it onto your new LED ones.
You're right about the surround... ...these are the same as the ones AutoBarn stock... ...I've been looking for something like this too... ...but I want them to be totally clear... ...No red... ...until the breaks or drivers come on... ...I just don't like the look of the small red dot in the middle...
I've seen some frosted white ones at Autosalon... ...But they didn't look like they had LEDs in them... ...Just couldn't find the owner of the car to ask him where he got them...
Anyone know where I can get these???...
No Red = Yellow Sticker - ADR's require rear lights to have red reflector that is highly visible when struck by a beam.
Why go clear? the stovetops are part of what makes a 'line a 'line IMO, semi unique to the lineage (i realise that there are others similar, but it's the only one i can think with four distinctly separate lamps)
Yay i've finally been spotted!
Hey guys, this'll be my first post, been browsing for a few weeks and going to sign up march 1 at RE Customs day. I'm the owner of the frozen r33 with a jurassic theme going on - not many people got that at autosalon, they thought it had water and clouds and shit going on but the car itself is frozen! U see me around i'll stop to say hi.
Anyways, as for my tail lights they are LED's when the lights come on. I made them myself. what i did was:
Brought some old ones from the wreckers to do a test first in case i stuffed them up
put a drill hole in the middle of the red lenses
got a heat gun and used the holes as leverages to hold onto while i pulled them off (its actually 1 piece joined in the middle but the glue just goes all around)
had my mate at a plastics place make me up some inserts which the LED's were drilled into and put together
then i got him to make me up some surrounds which i used his plastic glue to put back together!
it's that easy - the insert piece which holds the LED's goes behind the circular rough edges insert just behind the lenses, so it looks sweet and uses all the original parts
if you got any questions, or want some more pics, gimme a buzz
otherwise hope to put some faces to the usernames when im there next weekend
shanus
shanus
Ahh... ...I hung around your car for quite a while that weekend to ask you about them... ...But had to stick around our own display...
I'm guessing from the photos you put up that the reflector inside is white/clear and the whole outer cover is the red part...
yeah that's right. once you open up the 33 tail lights you'll see that the way they shine red is only by the red lenses covers. The inside reflector part is plain and has nothing to do with its color, and chucking in a red globe or red LED globe on it's own is not enough! But the bonus is the circular rough edges outer part just under the lenses is already clear, and reusable! it would look crappy if this part wasn't re-used. i'm pretty happy with the way they've turned out, and surprisingly it was the most frequently asked question everywhere i go. cheers
  • 6 months later...
correction... require reflector. doesnt have to be red.
clear reflectors will do just fine
pushbike clear reflectors are cheap and can be fabricated to replace red ones in tail lights
Woah... ...Digging up old threads... :P
  • 4 weeks later...
mine are now for sale - i got sick of the clear look and i wanted to take most my car back to standard for less reasons for cops to annoy me. if anybody is interested pm me. looking around the 250 range, the leds alone cost over 100 and i had to buy some spare sets for another 100 then all the plastic parts custom made so i'm out of pocket but will negotiate.
cheers, shane
and you dont need to tell me if you think they are awesome or ugly, i dont care for opinions, just want to move them on thanks.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
