Item:Various
Age:new to 8y/o (2000 model GTT done 55000KM )
Condition:used
Price:various
To Fit:R34 GTT
Contact:Wayne via email/PM
Comments:
Okay:
Coil pack sold
Intercooler Sold
Argh... forgot the short shifter!
This is supposed to fit an R34 - I fitted it but couldnt select 5th or reverse... hmm (!)
It it otherwise new (apart from being installed and removed, obviously).
Billet stainless shaft with Chrome coating with 'Nismo' stamped into it.
Came in a plain brown box, so is it a genuine Nismo Item - I doubt it??
It is also 'supposed' to fit 32's & 33's but frankly I do not know if that is correct or not, as it didnt work properly in my 34 box. All parts as originally supplied included in original box.
So I am selling on the basis that the above info is understood - perhaps somebody else has a better clue than I and can take advantage of it :thumbsup:
$55 plus postage or welcome to pick up. Sold
Xforce 3.5" exhaust system - all pipes from cat back to muffler (with silencer), including resonator.
From my '34 - these are approx. 3 weeks old, done less than 1500KM, so they're in very good condition.
Decided to change to a Varex muffler... so out they go: $320.
Complete & original exhaust system from 2000 model R34 GTT - done 55000KM - $140
2 x Ignition DVDs, Issues 16 & 27 (the latest): $10 for both plus $5 postage (or pick up)
Please see pics for (most of) the above items.
Large items are pick up only, or arrange own courier - I might be able to deliver to certain parts of Sydney if you cover my fuel costs and I feel like a drive :happy:
Please PM or email any queries, I'll do my best to answer them ASAP
Cheers :rant:
Edited by Wayne_J
More stuff added.
Also, I still have the original full exhaust system for this car, it's done about 55000KM and in good shape.
I am considering selling it if the new mods to my current system turn out really well... especially if there's any interest shown. If so please let me know :D
Coil pack sold, more items added...
Also have R34 GTT speedo cluster I'm thinking of selling (replaced with Nismo cluster), 55K on the odo...
Cheers
Ad updated, also with revised prices!
Moving interstate very soon & would rather not take this stuff with me, especially the xforce stuff. Bump!!!
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
