Item:Various
Age:new to 8y/o (2000 model GTT done 55000KM )
Condition:used
Price:various
To Fit:R34 GTT
Contact:Wayne via email/PM
Comments:
Okay:
Coil pack sold
Intercooler Sold
Argh... forgot the short shifter!
This is supposed to fit an R34 - I fitted it but couldnt select 5th or reverse... hmm (!)
It it otherwise new (apart from being installed and removed, obviously).
Billet stainless shaft with Chrome coating with 'Nismo' stamped into it.
Came in a plain brown box, so is it a genuine Nismo Item - I doubt it??
It is also 'supposed' to fit 32's & 33's but frankly I do not know if that is correct or not, as it didnt work properly in my 34 box. All parts as originally supplied included in original box.
So I am selling on the basis that the above info is understood - perhaps somebody else has a better clue than I and can take advantage of it :thumbsup:
$55 plus postage or welcome to pick up. Sold
Xforce 3.5" exhaust system - all pipes from cat back to muffler (with silencer), including resonator.
From my '34 - these are approx. 3 weeks old, done less than 1500KM, so they're in very good condition.
Decided to change to a Varex muffler... so out they go: $320.
Complete & original exhaust system from 2000 model R34 GTT - done 55000KM - $140
2 x Ignition DVDs, Issues 16 & 27 (the latest): $10 for both plus $5 postage (or pick up)
Please see pics for (most of) the above items.
Large items are pick up only, or arrange own courier - I might be able to deliver to certain parts of Sydney if you cover my fuel costs and I feel like a drive :happy:
Please PM or email any queries, I'll do my best to answer them ASAP
Cheers :rant:
Edited by Wayne_J
More stuff added.
Also, I still have the original full exhaust system for this car, it's done about 55000KM and in good shape.
I am considering selling it if the new mods to my current system turn out really well... especially if there's any interest shown. If so please let me know :D
Coil pack sold, more items added...
Also have R34 GTT speedo cluster I'm thinking of selling (replaced with Nismo cluster), 55K on the odo...
Cheers
Ad updated, also with revised prices!
Moving interstate very soon & would rather not take this stuff with me, especially the xforce stuff. Bump!!!
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
