hey guys
i have dyno'd my r33 s1 and got a very rich 170rwkw. basic mods, fmic, exhaust, coilpacks, STOCK boost / turbo
i finally hooked up some data logging equipment and found out my air flow meter is hittin 5.1v at 6000rpm (just when my AF ratio plummets to 10.5)
now its fairly safe now obviously, besides clogging my cat and killing my wb02, but this leaves no head room for me what so ever if i wish to run a bit more boost and reep some more KW
i thought the AFM would go to 190-210rwkw before i started having headroom issues? is this normal?
and i have spent HOURS hunting down boost leaks, only ever found one AGES ago :thumbsup:
https://www.sau.com.au/forums/topic/207223-maxed-out-air-flow-meter-170rwkw/
Man that's running pretty rich.. it goes lower than 10:1 but they haven't scaled it so you can see exactly where it goes..
Looks like a boost leak to me. Turbo is drawing air in through the AFM but the air isn't making it to the engine as it is escaping somewhere - so the ECU is pouring fuel in to suit the amount of power you SHOULD be making/the amount of air that should be making it to the motor but since the airs not there you are just running really rich.
Times like this I wish I had an AFM, as I think I *might* have a boost leak though not too sure.
hey guys
and i have spent HOURS hunting down boost leaks, only ever found one AGES ago :O
Does sound like your AFM has either bit the dust or like i think has already been mentioned, has a leak causing incorrect metering to the ecu
Testing with someone elses known working AFM is going to be a great test but you could also simply try taking off your AFM and giving it a good once over with some CRC Contact Cleaner!
170rwkw @ 7psi?.
I had similar mods before i put a boost controller in and i was getting 185rwkw (exhaust, pod, fmic, but tuned with a power fc)
i would assume this was due to the turbo back exhaust, but my stock solenoid was now running my car at 9-10psi.
i've got my old dyno sheet somewhere on my floor no doubt :D
Not sure how you tested for boost leaks but here is a cheap way to do it and very effective.
http://www.vfaq.com/mods/ICtester.html
I'm sure almost everyone could make one of those..
thats how i tested mine. hardest thing about doing that test is the fact that there is a million breather pipes that come off the intercooler piping and vent to the intake manifold and the engine. i could only pressurise the system for maybe 5 secs at a time. but had unlimited amount of air so i spent ages doing it. only found one leak and fixed that.
ill try a mates afm, then maybe put my smic back on, see if that changes my a/f ratio and my afm readings.
cheers guys
How would mixtures affect an airflow meter's reading? Its purely based on the amount of air flowing through it, which is related to the size of the turbo and amount of boost being run, not the tuning though.
Better mixtures would help make a bit more power though as you've said.
Also, the management currently is stock ecu, no remaps or anything (Id hate to see 10:1 mixtures on a so called 'tuned' ecu :banana:)
And Pegg, Ill lend you my AFM for a bit and you can take it for a whirl, see if that makes a difference. Msg me :P
Also, the management currently is stock ecu, no remaps or anything (Id hate to see 10:1 mixtures on a so called 'tuned' ecu :( )
And Pegg, Ill lend you my AFM for a bit and you can take it for a whirl, see if that makes a difference. Msg me :)
Exactly my point, the engine may be using 200rwkw worth of air, but because it is drowning, it makes significantly less power. That combined with the severely retarded ignition timing that it would be running explains the power loss. You really need to get some management in it.
Edited by Adriano
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
    • So I'm confident in saying its TCS thing. My new cluster I never realized didn't even have bulbs in the TCS or Slip slots. Shining a light through the backside that black plate has nothing for it, unlike my original cluster. Looking at the service manual the only thing that stands out is TCS in relation to the vehicle speed, it has nothing to do with turbos. It sadly looks like I may just need to get the appropriate cluster.
