a 3076 will bolt up to a standard manifold, but you may need some oil fittings.
as for the ecu, any aftermarket ecu will do the trick. you are best of asking the person who is going to tune it what they prefer. by using what they know the best you will get the best tune from them. if u get something they aren't familiar with you won't get as good of a result.
and i think a 3076 might be a bit big for a rb20 unless you are chasing big power. it will partly depend on what housing size you get.
but i don't know that much about what turbo is suitable for rb20's.
https://www.sau.com.au/forums/topic/207228--/#findComment-3666401
It does fit on the standard manifold...but by about 2mm you are best off getting a spacer made up to give the compressor a bit more clearence, apart from that you may need new oil and water lines and the intake will need to be jigged slightly
https://www.sau.com.au/forums/topic/207228--/#findComment-3666414
actually the spacer you need is about an inch thick. i installed a 3076 on a mates 33. and you will need a new intake pipe as the compressor housing needs a 4" intake , and you need to make a few mods to the 'hot' cooler pipe.
a good bolt up replacement is a highflowed r33 turbo from gcg. they are a 100% factory fit, but as your turbo isn't standard some of the oil and water lines may have been altered, but a trip to a local hose place should sort you out.
https://www.sau.com.au/forums/topic/207228--/#findComment-3666438
ya an inch thick is what mine was too! i was saying it did 'fit' straight on to my manifold by 2mm but it was deemed more clearence would be wise ha ha
Im gonna be unoriginal and say that a GTRS or garret equivalent would be good on a RB20, cause the 3076 on my car felt a little laggy and that was with a 25
https://www.sau.com.au/forums/topic/207228--/#findComment-3666608
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
    • I've done about 4000km's on it. I'm thinking of maybe "Working" from home aka my garage this week and getting it out so I can drop it off early next week. He said bring it over right away and didn't make any excuses, so it seems like he's going to work with me on getting it resolved asap. I'll let you know what I find when I take it apart later this week.
