Just want so information on the best way to remove the internal gate setup I have a brand new XR6 3540
I have gone highmount with external gate, is there a way to do it without welding the internal gate flap? If possible I dont really want to butcher it in case I come to sell it in the future.
Cheers,
Dan
Purchase a WG'less rear turbine housing... something smaller while your at it, so it spools :D
Most other things i can think of, that would actually seal... would be pretty gheto.
Edited by GeeTR
Its going in a RIPS RB30DET so it should spool ok (i hope)
Is it as simple as buying a 1.06 hosing from GCG for a normal Garrett 3540 my worry is that the XR6 version is slightly different
3L - ahh cool.
Theres only one way to find out :D Call a Garret pusher, or GCG or somone that would know. I cant imagine an Australian car using something too special derived that far from a OEM off the shelf product.
Edited by GeeTR
ok just got off the phone from MTQ re housings
You can fit up any of the normal Gated/non-gates housings to the XR6 3540
He recommended for up to 450hp keep the internal over that go external also thinks the 1.06 will go really well on a 3L bottom end
Apparently the housings are $980 from ford so i should sell mine on the ford XR6 forums as it is brand new, he quoted $570 for a new 1.06 external housing
450hp (I assume at engine)
You want 350rwkw which is 470rwhp, so you were correct about wanting to use a ext gate to do the metering.
In the end, looks like you'll be making some cash out of this :banana::P
Edited by GeeTR
Wouldn't it be easier to just take it back to whoever sold it to you and say exchange this for a normal GT3582R in whatever sized turbine housing you like ?
Personally I think you are better off buying something that's closest to the final form you want to run it in , no stuffing around with housings then .
If this is a road car I would still consider the 0.82 A/R turbine housing size . If it was an all out race only car with a close ratio box slicks etc then yes a 1.06 for sure .
I think an RB25 headed RB30 will have porting and valve train limitations so its worth considering how far up the rev range the turbo comes on line , in other words if it has a lower redline than a 2630 then the higher up it starts the narrower the power range becomes .
Your calls , cheers A .
It came with the motor I bought and I believe the seller of the motor had a friend who worked at ford
unfortunately I dont have time or money to buy another turbo and sell this one off
The rears are the same, and I reccomend grabing the 0.82 rear because even on your 3.0l a 1.06 housing will be laggy (close to 5,000rpm)
i get 15psi by 4000rpm with my manual powered rb30 twin cammed r32 using an xr6 turbo!
