um lol u seriously wanna compare a GTR to a GTS... well.. hmm
there's no comparison.... if you can afford it get a GTR, if you can't GTS. If you want sumfin that's drivable every day and won't scare the pants off ya, then get a GTSt. GTS is too boring... mines a daily driven and is basically my run around car. Can't wait to get my weekend car next yr :O
It depends on your wallet size... 40k should see you in a GTR, 19k should see you in a GTSt, 15k should see you in a GTS. What's can you afford?
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435054
JAGR33 is close to the Mark as usual I sold my old 97 for $48500 about a year ago had done 50,000kms only small modes such as Power FC, pods, injectors etc. Damm I miss that car. V Specs go for slightly more.... Find me a 97 for 35G and I will buy two!! Mine had 250kw at all fours wiht budget mods so easy to get more power from.
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435449
Guest 180sx_nissan_guru
JAGR33, it aint that hard. shit i drove past a car yard the other day and they had a white R33 GTR sitting in under all the commodores. you just gotta look around. look in dealerships AND look localy, like around the streets, it aint that hard.
or if your really desperate just go and import one, should save you a few.
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435472
My GTR is a 97 and 2 years ago it cost well over 50k. The car was in very good/excellent condition.
Nowadays, you'd still be looking at around the 50k mark for a good condtion 97 model.
95 models are around the low-mid 40k mark. I infact know a 95 model in excellent condition being sold for 43k if anyone is interested.
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435792
dont argue with jack... he's BIG and scary lol!
but there is NO was you'll get one for 35 G's.
dont bother arguing with the guys that have replied here, cause they all own(ed) one.
QUOTE OF THE DAY:
tell him he's dreamin
:D
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435818
well see the thing is i was just wondering if cops will be looking out for high performance cars and well i have two options get a GTR straight out or get a GTSt and then trade in the GTSt and get a GTR when i 'm off my P's
What dya recon would i get busted?
Or would you say as long as i'm not speeding or the cops don't have a reason to pull me over i'd be fine?
Or i'm i sure to get busted?
Thanks
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435893
Good R33's over here in Perth are still around the $50k mark unless you want a smash repair job. Series II's will be around the $55 - $60k mark for a good one.... Mine's a 95 and cost me $49k last year.
Oh and 260 - 280kw at the fly is waaaayy over the mark for a stock GTR. Maybe 220 - 240... Though very easy to get that with minimal mods....
I've owned a GTST and the GTR and they don't compare. A GTST is a good car and is better than anything aussie, but a GTR is in another stratosphere. Apples and Oranges if you try and compare the two....
my 2c
Brett
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-436117
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
