Can anyone suggest where would be best to go for a street/race package....by that i mean taking a stock 1992 r32 gt-r and fixing it up to suit street and track use.... i would like atleast 300kw at the wheels....
So far DRC, CRD and DART are on my mind but i havent had any time to go there during business hours to sit down and chat.
Thanks.
Edited by R33GTS25
https://www.sau.com.au/forums/topic/207303-r32-gt-r-streettrack-package/
Thanks.
I recommend before you spend somewhere in the region of $10-20K of aftertax dollars, you do make the time to "sit down and chat".
300kw street/track?
turbos and dump pipes $4k
cams and cam gears $1k
front pipes, cat and cat back exhaust $500
springs, shocks, swaybars, full set of bushes $4k-$12k
big brakes $1600 just jap or $6k brembo/alcon/ap etc
ecu and tune $2k
injectors, afms etc $1k
bigger wheels to fit over brakes $2k
semi slicks $2k
r&r engine to fit sump $1k
big sump $500
seats and harness for track use $1k
+ built engine with forgies, rods, head work another $10k if you want to do that as well
I love someone who doesn't have a budget :(
Here's what I did to mine.
Turbo's (HKS GT2530's)
Oil Cooler
Intercooler
AFM's
Cam gears
ECU (PFC)
Brakes (Porsche GT3)
2nd set of rims + Semi's (driving round on semi's all day isn't cheap or fun)
Zorst
Tomi sump
adjustible cabmer and caster (i should have done the rest of the suspention, but I got other things to spend $$ on now)
Diff (mine was single spinning :) )
ended up with 311rwkw, and even though the suspention is average, it's consistantly round the top 1-4 in times at the track.
I've done most of the work myself though, dam you and your endless budget :( . If I had more $$ i'df done the engine, i'd recomend you do the engine.
Edited by sav man
With no budget... DAMN! As of above on what everyone has said. + its easy to take advantage of the power of a RB26. Don't forget your Boost Controller.
Edited by (00)SKYLINE(00)
actually take it to racepace in melbourne not the ones you mentioned above. they have done much more development of the cars rather than just bolt ons, and have got good results out of 330-350kw cars
Hi mate I would recommend that you take your car to Powerplay as they are
about the only place I would recommend they have a very good rep and old
fasion service which is hard to beat.They have cars come to them from all
over the place Greece/Qld/Vic and so forth.They get a lot of cars in that other
so called performance shops have attempted to modify and they have come
to the rescue for the customer.It wouldn't hurt to give them a call
I guess he does have an endless budget right? Powerplay will be right up his alley :)
To add to all this, might be a good idea to purchace parts yourself if you would like to save a few grand here and there.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
