hey all as above ive done a 5stud/skyline brake conversion so im betting rid of my standard bits
can seperate or sell complete for $250
parts include
standard- ceffy calipers an discs, all 4
- ceffy front lower control arms
pm or msg me on 0431 891 433
https://www.sau.com.au/forums/topic/207313-fs-std-ceffy-brakes-and-4-stud-hubs/
  s_13 said:
Hey mate have you got the rear backing plates by any chance??? i need them for handbrake setup
nah sorry mate only unbolted the center hub section out when i did the conversion, had to cut the crappa outa my backing plates to make fit my new rotors
  2gceffy said:
what condition are that rotors in ??
last i checked they were ok, but have been sitting a little while so might have surface rust, nothin a light machine or using that would bring them up nice again
  • 5 weeks later...
i have same stuff for sale.
I DO have the backing plates and can get the disks machined for you if u want mate :P we do it at work hell cheap :D pm me if interested.
also got almost new lucas rear pads :)
didnt mean to hijack :)
  FROGGAH said:
didnt mean to hijack :blush:
LMFAO full hijack :down: , i'll chuck my cef's hub n struts in 2 seeing everyone is riding of the 4 stud crap lol.
standard cefiro brakes are quite good.
Ive done many track days and hills runs on them and I never have a problem with fading or poor pedal feel.
I know standard S13 brakes are crap - im not sure if they are the same.
they are very similar .....better pads and discs would help. Ceffy has ventilated discs in the rear where the s13 doesnt but i think the fronts are basically the same.
my old standard brakes sucked on track days .....4 laps and they were gone. very good on the street though ...as most brakes generally are. lol
oh and on the topic of hijacking threads......i have some 4 stud hubs, brakes and MC as well...haha
  • 3 weeks later...
buy buy buy already
in bali for a week on this tues so if for sum reason sumone wants to buy them ill be back the following tues
also ceffy standard rotors sold
  • 1 month later...
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
