Any updates? Curious to know/hear/see experience on these clutches and if it's just all hype. Other option is just to get a run of the mill Xtreme Twin Plate organic and enjoy life and not worry about complications. My clutch is starting to do weird shit after 3x motors and 10+ years of abuse. When you ride it, and try to park the shit box, it sounds like a munted horse after 10 cones. -
How did you get a S15 diff to fit in your R34? I understand in a R33 with ABS but doesn't make sense as the diff is the same length as a R33 non ABS. R34 has 2x ABS rings and sensors on the output flange where as a S15 or R33 has the ABS sensor on the diff input flange area. -
Hi stupid question rb25s2. Don’t have igniter is that igniter built in coilpacks or in the ecu
If you really want good AC consider the frenchies kit. All modern gear, works much better and is lighter. But it is $$$$$$
