To night we put the Stag on the Dyno, and then i have a other deal with a other guy monday, then we messaure the car twice on two diffenred dyno's.
I will try to record a little movie, goal is more then 300 at 0.5 bar boost.
First Dyno finished, in 5. gear: 300,1 rwhp, and 340 touge at 6500 rpm, boost 0.42 ( External wastegate open at 0.4 bar)
Still the RB25DE Ecu on the car.
http://www.bilgalleri.dk/html/vid_vis.asp?VideoID=11797
I will put the car on another Dyno monday, and make a better video, this one is recorded with my Nokia mobilphone.
Edited by Stagea Denmark
  • 1 month later...
A little update.
Last week i installed a Bosch T044 fuel-pump, the biggest, still the old injectors, and today we had it on the dyno again, adjusted the ECU/Fuel to max, in these small injectors.
Result:
394, 5 hp - 441 nm - 0.94 bars boost, and 296,7 km/h.
Next week i get my 650 injectors, then we will try at 1,5 bars boost.
Mate this is going to be one of the quickest wagons in Europe. :)
Let us know when you chop an Audi RS6 Estate on one of the autobahns. :)
Thanks, yes the car is going well, i hope i have 500+ next week, with the new injectors.
  • 1 month later...
Hi guys.
Had my red Stag on the Dyno again, but the wastegate didn't hold the boost, but it still made:
424 rwhp a 1,1 bars boost, at 5700 rpm, and 540 touqe, rpm is set to max at 7800 rpm :(
After that, another wastegate was mounted, and a bigger turbo, a T70, i will put it on the Dyno again in next week.
Hope you can see the video of the Dyno here.
(Weight ballast was 100 liters of water.)
Link: http://www.bilgalleri.dk/html/vid_vis.asp?VideoID=15225
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
