Sounds awesome guys. Looking forward to it.
May even be able to get somebody to have a look at my car and see why its running like rubbish. I have an intermitant problem i cant find. The car still boosts up fine but it sounded like the exhaust was backed up or blocked and there is a load roar like noise. Its not like your normall boost leak and i cant find one anywhere. its really unresponsive and thought my cat had packed it in but thats not the case. It runs fine without it.
  • Replies 163
Posted Images
Yeah I should Turn Up I guess.
Im from Banora Point (basicly Tweed) So we could even get a Tweed Crew Going.....JKS
Im broke till saturday lol so hopefully Ill have some fuel left.
But ill come say Gday.
Andrew
im in banora aswell. im really a true coastie but im down here for a while until i go overseas. how come i never see skylines down here!!!!??? where are you!!!!!! lol
hey guys, ill be working till 8 but will just be down the road at the q store so i mite pop in if ur still there just to have a look and see how many people turn up. look out for what will prob be the only 4 door 33 there. irish.
Long33 - I drive a 350z blue coloured 33 with URAS NS-01 Wheels and a busted up front bar and passenger side guard from when a kangaroo kamakazied itself into the side of my car in victoria.
btw I live off Darlington Drive, How bout yourself?
Cant say ive ever seen you car around.
See yas All tonight :D
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
