As above, everything was fine then one day brakes lights weren't working.
So i checked the brake fuse, it was blown.
With a new fuse in i press on the brake pedal, blew another fuse.....
Has anyone ever come across this before?
Edited by lows_13
https://www.sau.com.au/forums/topic/207371-r32-skyline-keeps-blowing-fuses/
could also be the globe filament shorted to earth or across the park lamp filament.
start by changing or atleast properly checking the globes then do the wiring checks.
if you have a boot mounted light in spoiler check that wiring hasn't chaffed through as well.
why on earth would you edit your first post, and not say what the problem was.
you wanted help, people posted up, and then you try to "hide" things when it is fixed?
I reckon it was water in the tail light btw.
