Fitting Stock Suspension
gtrzilla
 Share
Im thinking of removing my Teins and putting in stock GTR shocks and springs
Do i need a sprng compressor to get the tein springs onto the shox or can i just do the whole job at home
From what i have read on here, fitting suspension is supposedly fairly easy
:thumbsup:
If you need the spring compressor really depends on how long the springs are. If they're lowered by at least 2", there shouldn't be any need for a compressor, but you should get one just in case. It's not that expensive, I think I purchased mine for about $50.
Compressing the springs where a bitch to do because you had to get it in the perfect position on the spring otherwise it won't fit (into the car). Things just get into the way. Can't remember the details, but when I was replacing my rear shocks, I just recall being pissed off about the compressors. hahah.
Fitting new springs and shocks isn't too difficult. As long as you've got the right tools, it's fairly easy.
i figured i just put springs on the shocks and thats pretty much it for that
they are tein springs, lowered by about an inch i think
stock shocks
Yeah, it was like that for other car's I've worked on as well, but for the skyline, you had to install the springs and shock as two separate things. You had to get the springs compressed so that you can screw the shock's top nut (to the car) while the spring had to sit on the seats in the right position.
Most of the time the compressors would get in the way and make the springs sit in the wrong position on the seats.
But yeah, I've always thought that there was some top for the springs and shocks to go in as once piece just like any other 'normal' after market kit. Mine didn't, it's a GTS-4, but it has the same suspension as GTR's so.... :banana:
  • 2 years later...
im gona be attempting to remove my stock suspension and put in nismo s tune coil overs
had a look under the car, doesnt seem that hard to remove/replace, unscrew the 2 bolts on the strut tops and the big sigle bolt on the bottom of the shock
im going to buy a spring compressor just incase !
won't the Tein spring rate not be matched to the factory GT-R dampers?
Exactly right. I just went through this whole process of taking out stiff coilovers.
My process was:
stock suspension both springs and shocks are too high.
Stock shocks and lowered springs will wear out the shocks very quickly, plus the handling will be poor in the meantime as the shocks cant control the lowered springs properly
I ended up doing the following:
Bilstein shocks with lowered king springs
End result great handling and comfort. You literally dont feel smaller bumps and the larger bumps feel like small bumps. The car is also faster on any imperfect road and i honestly cant tell the difference in handling even on a smooth road.
The big thing is that you know its going to last. Would be a shame to go to all this effort for poor handling and then have to swap the shocks again.
I had to obtain some strut tops as the coilovers replace them, thats on an R34 GTT so it might be different on the GTR.
 Share
    • Yes if u mean by the plastic section behind the radiator?
    • This is the issue as the stock gauge I have heard won’t really read correctly and if it moves up it’s already too late. Mine moved up a little - I would say just past middle. Hence my motor wasn’t cutting off below 6500 max boost, I think if the temp was really high it wouldn’t go pass 3000 … that’s why I wanted to run a separate more efficient water guage and sensor to check readings closer - if anyone else is running them? And add a boost gauge while I’m at it.
    • Running a complete link setup now with a tune… reason I think it’s heat related as it only does the cut off after 30 mins of driving in the heat and didn’t do it at night time when the temp came down. Otherwise will look at the data and possible change the over boost max boost settings on the ecu. But yeah your right little guessing…
    • turbo removed and inspected, actually hoping to find a broken turbine shaft or something, (would explain a lot) but it looks great, no play or noise of bearings, solid connection on center shaft, both wheels and housing look fine inside and out, actually a lot cleaner and better condition then I expected...so I put back together and took for another drive, since I now seen other videos with similar sounds, I pushed the rpms' higher from 4-6k range, and got anywhere from 5-7 psi boost boost being created by turbo. so it appears turbo is making boost fine, however still the sound remains the same, the type of sound I would image if one side of the turbo wasn't connected to anything, (the sound of a leaf blower or hair dryer wide open end) is there anyway something could be preventing the air that is being forced out of the turbo to not be directed into the engine intake properly??, I checked all piping for blockage etc. none found.   still the power, torque and acceleration seem low, as it almost feels like the boost that is being built up is actually holding the engine power back and or its not being directed into the intake properly? I am tempted to make a super short U pipe to go right from the turbo out to the stock intake pipe and completely eliminate the intercooler and piping system just to isolate it.
    • What actual temperature is it hitting?
