Hey Guys
Just wondering when is the release for the evo x in australia, was in NZ and saw a few around are they out here yet. Also what price are they expected to be around. Wouldnt mind getting one well either that or a 34 GTR but will see. Want a R35 but dont think I can wait till the get realesed in australia or compliance gets happening.
https://www.sau.com.au/forums/topic/207399-evo-x/
Latest info I have seen is late March, early April. Looks to come in two variants, GSR and MR although the MR hasnt officially been named that in Oz yet.
Price wise $60K for the GSR and $70K for the MR. The MR includes some extra trickery like the MR version of the previous models such as Bilstein shocks etc.
https://www.sau.com.au/forums/topic/207399-evo-x/#findComment-3669542
Yes potentially there are some mechanical differeneces, article:
http://www.drive.com.au/Editorial/ArticleD...ArticleID=43984
A second model, which may be branded the Lancer Evolution MR - though Australian naming has yet to be finalised - will cost around $69,000. In addition to the GSR equipment list, the MR will add lighter Enkei alloy wheels (said to save 3.7kg overall), race-ready suspension (Eibach springs and Bilstein dampers) and a high-performance two-piece front brake disc.
Mitsubishi Australia is still putting the final touches on price and specification levels, so it's not known if both models will come standard with the five-speed manual transmission, or whether the higher spec MR will get the new TC-SST semi-automatic gearbox, complete with two computer-controlled clutches.
https://www.sau.com.au/forums/topic/207399-evo-x/#findComment-3670021
I went to the launch of the EvoX last year with Matt Lowth and a few others. Car looks pretty good. The MR is going to kick ass over the standard EvoX though. The interior is just so much nicer. DSG style shifting and paddle shifting is also very cool.
I think I posted some pics up in a thread awhile ago.
https://www.sau.com.au/forums/topic/207399-evo-x/#findComment-3671019
So u gonna get one Leewang?
Nah, not getting one. After looking at it more carefully, even though the interior is prettier and it's got more safety stuff, it's too heavy and I think a IX would still be a better car for our kind of usage.
For an all rounder though, the X MR will be an ace car.
https://www.sau.com.au/forums/topic/207399-evo-x/#findComment-3671458
Looks like the manual tranny is on its way out very soon... bring on the paddles :ninja:
https://www.sau.com.au/forums/topic/207399-evo-x/#findComment-3674507
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
