Hey all. Yeah my tacho finally died to in my r33. It still shows a few revs but not working properly at all. I was just wondering, has anyone attually repaired one of these. I have taken the tacho out of the cluster and i now have it on the bench setup with some power so i can test it all out. I am just about to start checking out all the components etc and try and find what might be the problem.
Is it possible to fit maybe an aftermarket tacho in the same spot. I am not sure which way to go at the moment. I will just play around with in n see how i go.
Any info you have guys would be great.
Cheers
https://www.sau.com.au/forums/topic/207450-stupid-tacho/
I have tested the signal coming from the ecu etc and you can see that it varies as you change the revs as expected. So i figure the signal must be all good. just the stupid tacho. I am having a play with it right at the moment. I will tell ya all how i go with it.
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3669821
LOL sorry mate i will try to hurry up :laugh:
I had a bit of a play with it. I am not sure what signal to give it to make it work. There is three wires that go to it. Ignition, Ground, and Signal. I connected up 12volts to the ignition and ground connections. I then put the meter across the signal and ground connections and it seemed to be giving out 9 volts. Not sure why this is. I was going to give it a variable voltage signal from 0.9 volts to 2 volts n see what that does.
I am not too sure tho if i am doing the right thing. I might have to do some more research i thinks.:P
Updates soon when i get more info.
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3669978
Yeah i might have to end up doing that too. My car is a 1995 series 1. I dunno if i can get a series 2 dash cluster and fit that. I not sure if they are the same or not.
It woudl be good tho to know what is wrong with the one i got tho. Might try an auto elec n see what they recon.
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3671982
yeaha dun need the factor boost gauge, anyhow, i have a cluster here in my garage i think, a mate of mine in his fto has the same problem, thing is it hard to find second hand fto parts..
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3672180
S1 and S2 clusters are exactly the same.
As i think has already been posted the 33 gtr cluster or even the nismo cluster will plug straight into a gtst
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3673290
  • 1 month later...
Actually I don't think Series 1 and 2 are the same.
I'm having the same problem with a R33 series 2 Manual Turbo GTS-T with the flickering tacho.
The Series 2 one I have has 6 circles on the left hand side and 5 on the right hand side for warning lights and airbag indicator.
I have-
checked and cleaned the connections with no luck
reset the ecu with no luck
checked the for sales forum for R33 Series2 GTS-T manual turbo with no luck
checked 4 Import wreckers for the same cluster with no luck.
So has anyone managed to fix this problem without replacing the cluster?
or know if you can pull apart and replace the faulty Series 2 tacho with a Series 1 one?
Any help would be great or else I'm going to have to start looking interstate or overseas soon.
Cheers
Michael
Edited by yaf28f
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3800639
Damn, mine just started freaking out today. Drive to bank, fine. Come out of bank, turn car on and tacho freaks out. Reads approx 1500 RPM higher than normal idle and movement, and is not steady but moves around erratically up or down 100-200 RPM. Would love to know a fix for this.
SII Manual Turbo
cheers
Evil
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3817667
while i was changing my headunit i took my cluster out and cleaned connectors and made sure everything was on tight, still no luck
just get a second hand cluster (from ebay or here in the for sale section) and just change the tacho section, its only 4 or 5 tiny screws holding it in place :rofl:
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3819838
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
