Hey all. Yeah my tacho finally died to in my r33. It still shows a few revs but not working properly at all. I was just wondering, has anyone attually repaired one of these. I have taken the tacho out of the cluster and i now have it on the bench setup with some power so i can test it all out. I am just about to start checking out all the components etc and try and find what might be the problem.
Is it possible to fit maybe an aftermarket tacho in the same spot. I am not sure which way to go at the moment. I will just play around with in n see how i go.
Any info you have guys would be great.
Cheers
https://www.sau.com.au/forums/topic/207450-stupid-tacho/
I have tested the signal coming from the ecu etc and you can see that it varies as you change the revs as expected. So i figure the signal must be all good. just the stupid tacho. I am having a play with it right at the moment. I will tell ya all how i go with it.
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3669821
LOL sorry mate i will try to hurry up :laugh:
I had a bit of a play with it. I am not sure what signal to give it to make it work. There is three wires that go to it. Ignition, Ground, and Signal. I connected up 12volts to the ignition and ground connections. I then put the meter across the signal and ground connections and it seemed to be giving out 9 volts. Not sure why this is. I was going to give it a variable voltage signal from 0.9 volts to 2 volts n see what that does.
I am not too sure tho if i am doing the right thing. I might have to do some more research i thinks.:P
Updates soon when i get more info.
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3669978
Yeah i might have to end up doing that too. My car is a 1995 series 1. I dunno if i can get a series 2 dash cluster and fit that. I not sure if they are the same or not.
It woudl be good tho to know what is wrong with the one i got tho. Might try an auto elec n see what they recon.
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3671982
yeaha dun need the factor boost gauge, anyhow, i have a cluster here in my garage i think, a mate of mine in his fto has the same problem, thing is it hard to find second hand fto parts..
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3672180
S1 and S2 clusters are exactly the same.
As i think has already been posted the 33 gtr cluster or even the nismo cluster will plug straight into a gtst
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3673290
  • 1 month later...
Actually I don't think Series 1 and 2 are the same.
I'm having the same problem with a R33 series 2 Manual Turbo GTS-T with the flickering tacho.
The Series 2 one I have has 6 circles on the left hand side and 5 on the right hand side for warning lights and airbag indicator.
I have-
checked and cleaned the connections with no luck
reset the ecu with no luck
checked the for sales forum for R33 Series2 GTS-T manual turbo with no luck
checked 4 Import wreckers for the same cluster with no luck.
So has anyone managed to fix this problem without replacing the cluster?
or know if you can pull apart and replace the faulty Series 2 tacho with a Series 1 one?
Any help would be great or else I'm going to have to start looking interstate or overseas soon.
Cheers
Michael
Edited by yaf28f
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3800639
Damn, mine just started freaking out today. Drive to bank, fine. Come out of bank, turn car on and tacho freaks out. Reads approx 1500 RPM higher than normal idle and movement, and is not steady but moves around erratically up or down 100-200 RPM. Would love to know a fix for this.
SII Manual Turbo
cheers
Evil
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3817667
while i was changing my headunit i took my cluster out and cleaned connectors and made sure everything was on tight, still no luck
just get a second hand cluster (from ebay or here in the for sale section) and just change the tacho section, its only 4 or 5 tiny screws holding it in place :rofl:
https://www.sau.com.au/forums/topic/207450-stupid-tacho/#findComment-3819838
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
