Cleaning out my shed, this stuff has to go!!!
R33 Stuff
New Adj rear camber arms $200
Ohlins Height/damper adjustable Coilovers with helper springs (rear only) $SOLD
Custom ally fire extingiusher bracket. Bolts under drivers seat. $50
Dash Panel (yes the whole thing that goes over the dash to centre console) $80 jus needs paint
Guage cluster surround (painted a dark silver) $30
Set of rear carpet in good nik $SOLD
Stock GTST cooler $50
Side pipe with stainless steel tip. Bolts on before the cat. Mega Phat for track days. $80
Set of 4- R33/S14 5 stud stockies good rubber $300
R32 and R32 GTR stuff
Standard RB26 cams good nik $200
GTR/GTS4 castor rods (standard) $50 ea only l/h avail. R/h sold
Std RB 26 ECU $300
Std RB26 Cam gears (suit any RB) $50ea
GTR Engine fan $50
Stock GTR Bovs on pipe $150
STD R32/S13/GTR rear camber arms $50ea
RB26 STD turbo manifolds $75 ea
Pair of M's (K&N) Air pods with polished ally intake pipes Suit std GTR afm's $200
Pair of Turbos with dumps, in good nik (stock) $SOLD
R32 GTR fuel Pump $150 sold pending payment
Pair of RB20 Afms $70ea
Centre triple cluster $SOLD
HKS 264 exh cam Rb26/20 $400
Apexi hard intake pipes $200
JUN Crank Collar $230 sold
Std RB26 Conrods $300 (free pistons)
STD R32 GTR Rims with tyres $ SOLD
Rays engineering Gt Av 17x9 +20 (gtr offset) Perfect cond $1500 tyres SOLD PENDING PAYMENT
NEW Carbon Fibre VOLK Centre caps. NEW FROM JAPAN $200
TBO Side skirts for GTR. Need some work.. $220
MISC
Carrozeria (pioneer) 6 disc stacker $100
HKS Pod adapter-RB20-25 $20
email me for pics or purchase.
All reasonable offers considered
[email protected]
ph 0409117081
Located in Bunbury WA Will post at buyers cost
Edited by CMS Drifter
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
