Cleaning out my shed, this stuff has to go!!!
R33 Stuff
New Adj rear camber arms $200
Ohlins Height/damper adjustable Coilovers with helper springs (rear only) $SOLD
Custom ally fire extingiusher bracket. Bolts under drivers seat. $50
Dash Panel (yes the whole thing that goes over the dash to centre console) $80 jus needs paint
Guage cluster surround (painted a dark silver) $30
Set of rear carpet in good nik $SOLD
Stock GTST cooler $50
Side pipe with stainless steel tip. Bolts on before the cat. Mega Phat for track days. $80
Set of 4- R33/S14 5 stud stockies good rubber $300
R32 and R32 GTR stuff
Standard RB26 cams good nik $200
GTR/GTS4 castor rods (standard) $50 ea only l/h avail. R/h sold
Std RB 26 ECU $300
Std RB26 Cam gears (suit any RB) $50ea
GTR Engine fan $50
Stock GTR Bovs on pipe $150
STD R32/S13/GTR rear camber arms $50ea
RB26 STD turbo manifolds $75 ea
Pair of M's (K&N) Air pods with polished ally intake pipes Suit std GTR afm's $200
Pair of Turbos with dumps, in good nik (stock) $SOLD
R32 GTR fuel Pump $150 sold pending payment
Pair of RB20 Afms $70ea
Centre triple cluster $SOLD
HKS 264 exh cam Rb26/20 $400
Apexi hard intake pipes $200
JUN Crank Collar $230 sold
Std RB26 Conrods $300 (free pistons)
STD R32 GTR Rims with tyres $ SOLD
Rays engineering Gt Av 17x9 +20 (gtr offset) Perfect cond $1500 tyres SOLD PENDING PAYMENT
NEW Carbon Fibre VOLK Centre caps. NEW FROM JAPAN $200
TBO Side skirts for GTR. Need some work.. $220
MISC
Carrozeria (pioneer) 6 disc stacker $100
HKS Pod adapter-RB20-25 $20
email me for pics or purchase.
All reasonable offers considered
[email protected]
ph 0409117081
Located in Bunbury WA Will post at buyers cost
Edited by CMS Drifter
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
