hey guys,
i just had a brand new set of toyo T1R 255 on rear and 235 fronts put on.
everyone seem to be saying they are grippy for street tyres.
i am slipping every time when i put the pedal down. even on 4th gear. the light on the dash keeps popping up... do i need to drive it for another few hundred kms b4 it will start to get grippy?
or do i need bigger tyres? 265 maybe?
my car does not have huge power. i do understand if the wheel spins on first n second but this goes straight to 4th gear.
shed some light please.
cheers!
https://www.sau.com.au/forums/topic/207483-wheel-spin-even-on-4th-gear/
dynoed the other day 280rwhp. tat why i am curious aswell. its not a huge power, but y the "SLIP" light keep popping up.
was driving on the freeway yesterday n when i drop to 3rd & 4th, pedal down it slips. every single time.
I dunno how you could be spinning in 3rd or 4th with 280rwhp mate. I have cheapy nangkang 245s on the arse of mine and it wouldn't spin even in 2nd. Stab the clutch yeah sure you get a bit but wouldn't 'spin'. That's with 270rwhp in a lighter car.
are you refering to the slip light on your tacho as in an Active LSD?
slip light on the top of the tacho.
the car is a r34 gtt and it comes with the tsc(traction control)
Edited by lcy
How stiff are your springs?! lol
I'd take a guess here and say your traction control may be playing up.. when the light comes on, can you actually feel the rear wheels spinning? or is the SLIP light coming on with no wheelspin? May be a fault. It's also possibly something to do with your ABS as the wheel speed sensors can affect the TCS.
Why don't you turn traction control off and see that your wheels won't spin....in any gear for that matter unless you clutch dump it or power over in a corner, especially with T1R's. Otherwise it's probably as stated already and your clutch could've seen better days.
edit: added info
Edited by KeyMaker
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
