PRICE DROP!!!!!!
Item: Greddy Full Auto Turbo Timer + Harness for an R32
Age: Couple months
Condition: Perfect
Price: Was $100 it is now $70
To Fit: (What car) The Harness if for an R32
Contact: PM me or email me on [email protected]
Comments: In perfect condition...reason for selling is because just got a new alarm and it had its own turbo timer.
Item: 3 x Drift Guages (Boost, Oil Pressure & Water Temp)
Age: 5 months
Condition: very Good
Price: Was $70 each now $50 each
To Fit: any car
Comments: The guages work perfectly. The water and oil guages need the sensors as i am not including them in the sale as i have given them to a friend already. The boost guage is mechanical. These guages are blacked out when the car is off but when you turn the car on you can see the guages light up.
(Boost)
(Water Temp)
(Oil Pressure)
If buyer needs the items posted the cost of postage will be added to the items price..
Edited by vinnie32GTS4
https://www.sau.com.au/forums/topic/207500-greddy-turbo-timer-harness-3-guages/
Hey mate what colour do the guages light up?
its got a black background and all the numbers and stuff light up white..it looks really hot at night i must say lol
hey vinnie are u in melbourne? still got turbo timer? i give u $50 for it =D
hey mate sorry im in adelaide and dont really wanna go to much lower than 70 as i only bought it not long ago for 130
it was worth trying lol, yea im interested so how u wana do it and how much to get it into melb. cheers
let me know what postcode and i'll get back to ya
cheers
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
