ok folks here we have some goodies from my 95 R33 gtst due to some recent upgrades in the style and braking departments i no longer need these particular items so feel free to have at them and also feel free to pm me with offers...... reasonable offers will be carefully considered....... happy shopping
Item: R33 stock brake rotors and pads
Age: rotors: on the car when i purchased it in july 07, pads done 3 months back
Condition: used
Price: $180
To Fit: (What car) R33 (but feel free to experiment)
Contact: pm me for details
Comments: pick up only on all items in this thread.....
Item: R33 stock tail lights and rear garnish
Condition: used but good
Price: $150
To Fit: (What car) R33 (but again feel free to experiment)
Item: R33 stock brake lines front and rear
Condition: used but very good condition
Price: $50 fronts $30 rears
To Fit: (What car)R33
Item: 20 inch XHP DIRTY DOG CHROME RIMS X 5 (also comes with spacers needed to clear brakes)
Price: $2000
To Fit: (What car)anything with a 5 x 114.3 pcd.....
Comments: 4 rims wrapped in nankang rubber fronts are 225/30/20 rears are 245/35/20...... need smaller tyres on the front so it could turn..... also have a fifth rim w/o rubber with gutter rash (replaced it with a brand new one same day) some stooge ran me off the road into a gutter and f**ked my front left rim pictures will indicate condition of wheels.... will also provide a pic of the rims on my car they looked hot
Edited by punisher6942
kmon ppl i need this stuff gone...... if ya dont like the price throw offers my way.... all reasonable offers will be given great consideration
kmon ppl get into the spirit of things had a few time wasters hit me up if u want some good stuff.... bump
kmon everyone throw me some offers.... no reasonable offer ignored
  • 1 month later...
  • 2 months later...
  • 1 month later...
  • 4 weeks later...
PRICE DROP..............
brake rotors and pads $100
tail lights and rear garnish $120
brake lines front and rears $50 the lot
20in CHROME XHP DIRT DOG RIMS $1800
brake pads and rotors sold.........the rest is still up for grabs drop me a line ppl
  • 4 weeks later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
