Fs:20 Inch Rims, Stock R33 Brake Rotors And Pads, Stock R33 Tail Lights And Rear Garnish, Stock Brake Lines
What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot. -
Isn't this what everyone immediately sees in their mind's eye when someone gives them a total width number and an offset?
It won't be this - not while it's driving, anyway.
when does it run badly; hot/cold/both, idle/part throttle/full throttle what computer is running it and what data can you get from it?
Perhaps, and it's deceptively similar. I was yesterday days old when I first heard anyone mention that the default guards have exactly XXXmm space. No more "is 8.5+37 going to be flush/fit, or will it poke? how much? 9.5 +16.9?" etc. Can just do maths and subtract from 100 - Shit, Wheels should have this measurement stamped on them. "This wheel extends 74mm from the hub in one direction and 57mm in the other" This is a far better system than offset, inches, and backspacing.
