its not in that link so ill post one i highly reccomend, fours n more automotive, on langford street in pooraka. They have tuned my 31 and done alot of other stuff and hasnt missed a beat for about a year. Have a chat to brenton or david there and tell them luke with the r31 put you onto them. Their number is 82602011.
Edited by skylineguy19
i would also recommend tilbrooks on this one.....speak to either mark or michael....they know their stuff and my car hasnt missed a beat after being sorted out by tilbrooks....
Dennis at BoostinOz is great, they are in Salisbury.
i was speaking to a mate last night who got his car currently serviced by BoostinOz and he highly recommends them for future work....so give them a go and they are close by as well...
*slaps joel*
oi give jeff from the speed lab a call (he uses the turbo tune dyno, dont worry no one from turbo tune will be touching the car only jeff) save ya cash n get a remap done you will be suprised, get a bigger fuel pump n a controller or bleed valve before you get a tune!
The Speed Lab (jeff) 0434 637 357
If your gonna be using the standard computer i would also recommend Jeff from the speed lab
But if you having any other stuff added. Then i would recommend Simon from Morpowa
i would agree simon is good he tuned my old 33 back in the day, but i know joel has a stock ecu, i also read jeff can go to any dyno so you could use morpowa dyno if you want, power figures mean actually hang on, I have bad gastro. 2 secs. ahhh thats better.. all, its the tune you should worry about.
go to ns.com n search member TSL or the speed lab topics theres a few there with dyno result pics and reviews :D
Edited by shy_s6
EDIT!! you beat me too it.
Jeff's been flat out lately and hasn't been on NS for a while so better to ring him directly.
Jeff:0434637357
+1 to what was said above.
Also Jeff used to use Morpowa's dyno to do his remaps but now he has based himself at Turbo Tune. I'm sure if you threw a bit of cash at him he will still come to Morpowa for you.
Edited by D_stirls
he still travels arounds to dyno's you just have to book him in avance, Joel i believe i told you aaaages ago to take it to jeff and no one else :) a mate of mines car has same mods as you and jeff remapped it and makes 195 rwkw on 13 psi now... not bad for a 20 with 25 turbo.
thats who Grim_32 used aka Ben with the Rs260 he swears by Dennis
    • Yeah, hard to find and a pain in the ass to change with the transverse engine. I’ve worked on a GTiR before and it’s not a job I’d ever want to do again. theres a company in South Africa that makes RS3 gearbox adaptors for the AWD SR20 including gearbox mounts, so I could modernise it and go a dual clutch with paddles. For now tho, it ticks all the boxes. Super cheap, can throw the kids and their junk in the back, and SR20 that I can turbo cheaply, a CVT that’s not a dog’s breakfast like the V35, and has 80% interchangeable parts with stuff I can source from the wreckers cheaply…. But it’s still unique. I love the wagon back of the Autech version. It’s cheap enough that I can buy another stock manual FWD Primera with SR20VE, swap the gearbox to the N15 pulsar short gear ratio box, swap out the brakes to the R32 ones I pulled off my 32, register it on club plates and take it racing. $1300 shipping from NZ. Heaps of parts and aftermarket builders for transverse SR20’s in NZ.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
