mind if i ask a couple of questions??? with all u experience people out there. i am sure u can help me. thanx....... =)
1. Wat is the maximum boost with a stock skyline turbo?
2. Wat turbo is good to replace a stock one?
3. Wat does the turbo upgrade kit contains? For example the one in GReddy.
4. Where can i get one?
DRIVE SAFE !!!!
https://www.sau.com.au/forums/topic/20758-hie-people/#findComment-436555
LET ME SAY SOMETHNIG IN CAPITALS I READ SOME MAGS AND BEFORE I BROUGHT MY LINE I KNEW THAT STEVE (SST) KNOWS ALOT ABOUT SKYLINES PLUS U HAVE GRANT FROM PER4MANCE WITH THEIR KNOWLEDGE AND THE FOURM WE ALL CANT GO WRONG (speaking from exp ) they will set u right (stock turbo,fmic,zorst,261hp at 10psi)
https://www.sau.com.au/forums/topic/20758-hie-people/#findComment-436575
maximum boost on stock turbo no more the 13psi i pretty sure 14 psi is pushing ya luck
asking what turbo is good to replace stock one is like asking a chick what they want for christmas, everything! depends what your after in power terms
as for what is included in a turbo kit, again depends what sort of kit you get, genrally you can get kits consisting of manifold, turbo wastegate if needed and all the other bits and pieces needed for a full no fuss bolt on kit :P
where can you get one? any of the performance shops in perth: Per4manz turbochargers, Xspeed, Evo R, Works Auto etc........
adrian :(
https://www.sau.com.au/forums/topic/20758-hie-people/#findComment-436739
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
