Ae111 4age
Toyota Levin 1600cc twin cam
-4age 20valve Black top
-6 Speed close ratio gearbox
-ABS break system
Exterior:
Full aftermarket bodykit
15" BodyClub P1 Racing Alloy wheels
(4 X Bridgestone Potenza G3 195/55R15 high performance tyres)
FGK (Fujitsubo Giken) Full Exhaust
H7 7500k HID
LED Blue lights (4 sides)
Engine:
Champion spark plug leads
NGK Iridium spark plugs
Cambelt done on 91278kms
SSR Radiator Value ( 0.9 Bar)
4 X Auto Gauge meter (Vacuum, Volt, Psi Oil Press, Oil Temp)
Air Introduction Pipe with HKS Air filter
Sound System:
Kenwood double den MD (5 changer)/ CD Head unit
Front speaker: Alpine Rear speaker: toyota standard
TRD rear lower bar
4 stage GAB adjustable suspension
New brake disc
Uniden 5 Star Alarm and dual immoboliser and central locking
10G ONO SWAPS NO HOLDENS OR FORDS!!Keen on 190e,86,bfmr,vr4,gzr
 Share
    • It's basically the same platform, hence why everything bolts to everything else Kelford camshafts were recommended by Mania after they asked me what I want the car for, I said "I'll thrash it around daily and maybe take it to the track for fun" 🤣 Factory NC 2.0L cam specs: - Adv. Dur. 256 /256 - Dur @ .050 205 /190 - Lift 9.42mm/8.13mm So, as I know nothing about cam specs, all I can say is the numbers are different and it should get a little bit of lope....🤣
    • Depends on how extreme, however if you look at SMSP, they're all dominated by Hondas and M cars on amateur/street car events.
    • Without better pictures, it won't be possible for anyone to work it out further than we have.   Start measuring, EVERYTHING. Thickness of flywheel, and all around it. You want to know is if everything parallel. If from the face of the pressure plate (that bolts to the flywheel) if it is parallel to the pressure plate face, then something is NOT parallel or equal elsewhere. Or you've bent the shit out of the fingers in the pressure plate.
    • Finally getting around to changing whole cold side. (Look at that sludge) lets see where this leads once it’s all together tomorrow.
    • 0.5L sounds like nothing. But when it's a 25% increase in displacement, to a newer engine platform, and getting some speedy bits, it should be good!   Compared to stock cams for the 2.5L, are these new cams mainly more lift, or more duration too (shifting the torque curve into higher RPM)?
