hey i have an r33 gtst skyline i seem to have problems with it.
when i start the car when its cold the engine feels tip top.
when i drive for a while and the engine satrts to heat up a bit it feels like the car wants to stall and has an idle problem.
when i turn the car on when its hot it takes a little bit to find its idle...
it goes from 100 to 1000 in reving and sometimes stalls when i try.
also when i rev my car a little it sounds like there is a rattle where the timing belt is.
it kicks in at about 1000 and cuts out a little later.
things i have replaced.
oxy sensor
tps
engine and turbo
mods i have
hks airpod filter
carbon battery.
i have video of it
also my throttle cable feels lose as you can see in the video.
$15 will be rewarded with correct awnser for both things that need fixing.
i will slowly replace items once i know whats going on.
on thursday my car will get dignostics done.
i only ask this because everywhere i go machanics are like agrrrr this is the problem but its not really agrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
thanks alex
I've got some money on the AAC valve, or the Cold Start Air Valve (underside of the inlet manifold). But if you've replaced the whole engine, then those would have been replaced.
  • 11 months later...
Yeah sounds like your AAC is stuck open or the regulator is faulty
Pull the plug on and off to see if theres a drop/increase in revs.
What if there is a drop or increase in revs? Which is supposed to happen?
Edited by Neejay
  • 1 month later...
<br />hey i have an r33 gtst skyline i seem to have problems with it.<br />when i start the car when its cold the engine feels tip top.<br />when i drive for a while and the engine satrts to heat up a bit it feels like the car wants to stall and has an idle problem.<br />when i turn the car on when its hot it takes a little bit to find its idle...<br />it goes from 100 to 1000 in reving and sometimes stalls when i try.<br /><br /><br />also when i rev my car a little it sounds like there is a rattle where the timing belt is.<br />it kicks in at about 1000 and cuts out a little later.<br /><br />things i have replaced.<br />oxy sensor<br />tps<br />engine and turbo<br /><br />mods i have <br />hks airpod filter <br />carbon battery.<br /><br /><br />i have video of it<br /><br />also my throttle cable feels lose as you can see in the video.<br />$15 will be rewarded with correct awnser for both things that need fixing.<br />i will slowly replace items once i know whats going on.<br />on thursday my car will get dignostics done.<br />i only ask this because everywhere i go machanics are like agrrrr this is the problem but its not really agrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr<br />thanks alex<br />
<br /><br /><br
wow, we are in pretty similar situations, Ive done a rebuild, done the turbo and only got a pod filter. Yeah only rebuild the long block, so kinda sems like they gave me back this amazing engine block surrouned by sh*tty parts lol. my idle used to be all over the place, so i began replacing parts. i replaced the IAC valve,then eventually the whole unit, got new tps, got it re positioned, got a new throttle body and cleaned the unit out. That worked for my idle issues, never stalled or hunted around much again, only rarely. I'd also check for any vacuum leaks or cracked hoses, ask ur mech to do a compression test. rebuilt engines have so much power when everything around them is running right. also for your rattle, I'd suggest u check that all the bolts up font are tightened. Good luck wit it
Ben
  • 9 months later...
Ben, I am currently having problems very similar to this and you said you replaced your IACV Valve and i have ben told thats what i need to do but i am having a lot of trouble finding out where to get one, Nissan don't want to sell me the valve alone they want me to buy the entire unit and that is around $1k for something i dont need, could you tell me where you got your new/used one from please? I have a 1996 R33 series II.
  • 1 month later...
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
