If you want to do any street driving I would recommend going for a built jatco re4r03a as you still retain the overdrive but they are expensive compared to something like a C4.
The overdrive would be nice for street driving, granted, as would the bigger and stronger components of the RE403 over the Skyline 401 but like you said, they're much more expensive to build to take the power being suggested than an equivalent C4 or TH400 which are known quantities where spares are very readily available.
If it came to it you could get Mike from MV to put a JATCO together as he does some good work at reasonable prices but the standard Jap boxes are too hit and miss when you start leaning on them hard. I'd stick with something that you absolutely KNOW will do the job time after time.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3677753
cool thanks heaps...
ive heard the jatco's arent as strong???im not going anything nissan i have big plans for future and dont want to change but i still know next to nothing about auto's...
What about powerglide???
Any other choices or c4 is def the pic???
You could quite easily adapt a Turbo 400 or Powerglide to your engine but it's all about what you want to do with it. Having a third ratio is good for cars with narrow power bands. What does your car weight and how does it make its power?
The C4 is a relatively light and small (narrow) box as well so it's a good option in a drag car where every pound counts.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3683003
A built C4 is a strong box but dont under estimate the re4r03a as testing in the states indicates that these boxes will survive 1000hp and beyond.
The question is for how long, mate. Dom Rigoli had an RE401A in his 1000hp WRX for ages but how often was it pulled out and at least checked each meeting? It's a lighter car than ours too so who knows. 1000hp is one thing but in a 3300lb car it's a whole other story. C4's and Glides can hold that power in a 3500lb car all day so I know what I'd prefer.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3686510
The problem with the subaru re4r01a is that the output shaft is very small compared to say a skyline re4r01a and half the size of the re4r03a. Once they upgraded the output shaft size to powerglide spline size they had no more issues with breaking output shafts. I will be testing the limits of the re4r03a boxes soon. We have kept the shafts standard (other than heat treating) to see what weak links show up. These are larger than a v8 glide so any problems should be fixable using higher grade steel.
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3686587
Lost them there Smiley
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3709416
  • 1 month later...
probably worth a mention that with the rather large turbo you are running and depending on how
tight the converter is you will probably have to give the big girl a sniff to persuade it to come up on the brake. A small dry shot will do it, something like 50hp. Unless you want to be on the start line staaling it up while the other car crosses the finish line like most VLs you see
https://www.sau.com.au/forums/topic/207633-drag-driveline/#findComment-3810001
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
