probably worth a mention that with the rather large turbo you are running and depending on how
tight the converter is you will probably have to give the big girl a sniff to persuade it to come up on the brake. A small dry shot will do it, something like 50hp. Unless you want to be on the start line staaling it up while the other car crosses the finish line like most VLs you see
Its always possable but it wasnt too bad with the manual so the auto/stally/transbrake/2 step might be fine...
If im going nos ill go an even bigger turbo i reckon, or atleast just a larger hot side on the to4z...
the manual is nohing like an auto, and if you are looking to up the turbine wheel and or housing, you will definately need it.
if your converter is loose you might get away with it but mph will suffer badly.
  • 3 weeks later...
Hi, i got a rb20det r32gtst auto with a re4r01a rebuilt box with 2500rpm stall.
Can i just 'add' a transbrake to my application?
do transbrakes run off how big your convertor is or is it completely seperate?
My goal is to be able to stall it up alot more then 2500 but does that mean i have to UP the convertor aswell to match the transbrake?
obviously im new to all this...
cheers
Aaron
No. The transbrake is a part of the valvebody. If you don't already have one incoporated into your valvebody, you'll have to change this aspect of the transmission.
How high the transbrake will stall is directly related to how big the stall of your converter is although their not usually the same. i.e. you may see higher rpm on the transbrake than you otherwise would on the footbrake.
Maybe, maybe not. You could have your box pulled apart and the valvebody replaced and see how you go rpm-wise but if you want to stall it much, much higher than the 2500rpm you're currently set up with, you will almost certainly have to change converter.
It's still a standard auto valve body,will it need to be modified?
Completely.
so with current setup + adding a transbrake,i may if lucky be able to stall it to 3000rpm
Too hard to say as it relies on a great many other factors.
Do they modify the stock auto valve body to incorporate the transbrake? Otherwise im looking at a bigger convertor to acheive the big transbrake.right?
The simplest way is to fit a higher RPM stall converter.
for those that dont know how a transbrake works, in simple terms it engages reverse gear when first gear is selected. so you roll into stage in fist gear, engage T/B and then hold down micro-switch. reverse gear is then also engaged meaning that the transmission is trying to drive against itself. you then release the brake and apply the throttle firmly. boost can be built as there is obviously load as the transmission pushes against itself.
this is where the converter comes in. think of a loose or standard converter as a car with clutch slip. a loose converter will allow you to see alot of rpm while on the transbrake. this is good as it will come up quick, but it will behave like a car with clutch slip when you leave, giving you an average 60foot time and poor MPH overall. A tight converter is best but slower to see rpm and make boost. This is where Nos comes in.
Anyway you are on the gas at 4500rpm and 15psi. you release the microswitch which releases reverse gear and away you go. its like those toy cars that you drag backwards and then let go. the glove box flies open and shit goes every where and the front wheels are in the air for the fist 40 feet. cool.
Edited by BezerkR32
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
