the noise you want is as stated before.
HKS SSQV
or
Greddy Type S (The pink one)
If you search for the word BOV on this forum, you'll see why a couple of us make fun of it and lose patience with it all.
long story short, an atmo venting bov (the ones you want) on a AFM equiped car (Skylines), will cause more problems than benefits.
Your car will most likely stall.
your car will most likely backfire between gearchanges.
your car will most likely run rich in between gearchanges causing black marks on your rear bar.
there actually is no benefit of an atmo venting bov at all.
Only reason to do it is if you like the noise.
Cheers for that. That would explain why my car doesn't stall anymore now that I have removed the Blitz BOV. Note taken on board. I was doctrinated V8's like a freakin religion from a young age. This line is my first turbo car to which my old man still gives me greif about daily. lol. I don''t mind cause now I can beat his VE GTS so I say suck sh!t old man.
Thanks for the advice. It's funny how many dudes on here like to bag out any question that may sounds stupid to them. Really enjoying being part of the turbo scene though. So much more technical than V8's. lol.
Kick em in the shins hard, then again when hes on the ground for selling you such blasphemy :down:
What?? Its a BOV thread, im allowed.
hahahahahahah! Crack up! maybe it's pure brain wash but I still think nothing sounds better than an off it's face V8 at full tilt. The sort of sound that shakes the pillars of heaven. lol
I am however a converted man now! To be able to have a car that runs high 12's for less than 15k is unheard of in V8 land. I mean sh!t my old man paid 70+ for his GTS and still can't keep up. I think he's secretly in conversations with HPF and getting the CAM and EMS upgrade. Then it's on. Let the war begin I say.
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
