List is updated :D:) Also if you want an easier to read copy I have got a MS spreadsheet version
SAU ID PSN ID
Sl!m - VertexR32
Gts30t - Shodaddy
mattis96 - qik33
trism - t_r_i_s_m
r33cruiser - a_BFG
smurf80 - smurf80
MADGT4 - madsammy
OZ_Pomy - iLEC
Kozeyekan - Kozeyekan
thirty four - reggin_au
Goziiraaa!! - Bourne01
[Michael] - kaido
GoldZilla - GoldZilla
kralster - MrCharismaAUS
Magic - Blaq-Magic
typevu - typevu
Bumblebee- GT2-KLR
GeeTR - rkaid
S13Deviat - Andominated
YLD-CHLD - YLDCHLD
Krimz - krimzn
=premo= - incorrect_method
LEANBAC - LEANBAC
dezz - dezzmang
AMS - oconnorams
Dush - Dush
MaTBoY - matboy
atang - atang34
TiTAN - sau-TITAN
SKYLVIA - WildWarriorBizz
Kaz180 - Kaz180
ABuSD - KellyNUTS
krzysiu - KrzysiuR33
BAMR33 - bamr33
gt_relish - Gonzarelli
Frunknmont- fl1pp3
PSICO - McWhizzle
PWND - foamer
joe26f - Stagezilla
jeffboyracer -sjhanan
bigjimmystyle- Bigjimmystyle85
W0rp3D -warped
EVL-R33 -WarMachine
writeoff -writeoff3
muirsky -muirsk
hkspwr -hkspwr115
Ry34 - Ry34
omy-33 ashdroid
TheProDaniel- TheProDaniel69
Howie -Howiefied
hanyou -hanyou8
nismo_GTS -Ants84
Topaz - PaSs3y
fab34 - fabz_r34
NYL83R - Zoidberg01
Raikkonen - PointHrO
abu - rejektedd
noisia - joeleongate
Eeleye - Ee7eYe
Rhyses Pieces - ripin_new_ashols
Rodent GTR - harangozo
joe33 - VESSVUTE
NateR31 - natious13
RusH_ - RusH_au
  • Replies 112
  • 4 weeks later...
  • 2 months later...
  • 11 months later...
  • 1 month later...
  • 5 weeks later...
  • 1 month later...
Just to let people know I've added some random users to my PSN acoflamin mongrel. So please accept it. Not people on my friendlist play MW2 anymore and it's getting annoying finding some decent low ping games.
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
    • Genuine GTR seat? There are none you would actually want for <$3k a pair.
