the bulb in my left foglamp is out, and i have never had to change one of these before and it doesnt look as simple as lifting the bonnet and popping it in our out, do i have to take off the front bar or the bulb surroundings somehow or jack the car up and do it from underneath,
how do you change these little buggers!
you need to get in behind the front bar (where the fog light assemblies are) and undo the cap on the back of it (much like the headlight)...if you can get it on a hoist it'll be pretty easy to get in behind it, but I did it on the ground....just a bit harder to get your head in and under to see what you're doing etc....jacking it up will help obviously
two 10mm bolts at the back of the assembly, unplug the foglight/indicator connector
and press down on the clip at the back to take the assembly off
much easier fitting a bulb afterwards
Edited by POLICE
  • Like 1
I will do this, sounds like a smart idea
Anyone know the bulb # so I can get one before taking the assembly out?
Thanks
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
