Here is yet again more gear for sale:
Make a reasonable offer time all items listed in blue make a reasonable bid on
all items in red are firm prices!
Stock R33 fuel pressure regulator
Used
$20 $10
Genuine RB25DET water pump in box
good condition used
$50 $30
Bosch Wide band O2 sensor
used
$50 $40
Brand new Genuine Toyota Oil filter in box
suits 4A-GE/GZE, 3S-GTE, 2Y&3Y Engines
$10 $5
JAW Japan Shift light Brand new,With simple plug and play installation. Has been pulled
out of box to look at but has not been used
$100 (RRP $150) Sold
Starbo G-12 Turbo Timer
Used good condition.
$20
FET TB-508 Turbo timer
Used good condition
$20
Jaycar Digital Fuel Adjuster
Built from a jaycar kit. bult it myself works great.needs hand controller. dont need it now i have my power fc
$20
Small Nismo Sticker
$2
Brand new Genuine S13 Rear Silvia Bage
Still in box
$40 $20 (rrp $65-$80) Part # 99099-35F01
Brand New Genuine S13 Rear Nissan Badge
Stil in Packet
$20 $10 (rrp $30-$40) Part # 9909935F00
S13 SR20DET Steel intercoler pipe with adapter already fitted for blitz BOV
(from Stock cooler or arc upgraded intercooler to throttle body)
$40 $30
Autotecnica Horn button
Brand new
$5
All items now for individual sale
Buy all of this stuff plus all the gear from my other for sale post
http://www.skylinesaustralia.com/forums/Au...nd-t207193.html
and a stack of car audio gear including
Use all this stuff or sell it here or on other forum's or ebay it
to make a profit i dont care i just need all this suff gone.
Located in Sydney's Western Suburbs
All sales are cash only and you have to pick it up
$150 $100 $80 $50 FIRM for everything i want it gone including the audio gear
Kind regards
Dave
Edited by MR FLWLSS
  • Replies 49
Posted Images
Wide band O2 sensor, New oil filters, New subaru floor mats added
Toatal bargan price of $550 & $700 for the lot
Edited by MR FLWLSS
if you have anything you think i might be interested in im willing to swap the lot for something of interest to me :cool:
You sent me a PM, can you pm me a photo of the shift light out in the open.. I want to see the cover of it .. is it bling bling or black? what colour is the shift light itself?
price drop on total prices due to sale of hicas lock bar and digital speed meter.
Edited by MR FLWLSS
do u know if the flash light works of rpm according to the factory needle (which is a bit slow) or is it connected to the ecu rpm (realtime)?
actually its really cleaver its made so even a monkey can opperate it. it connects to power and thats it.
its rpm reference signal is the back emf that altinator produces. as the altinator rotates it creates pulses/bursts of energy, Because an altinator generates 3 phase ac current whitch is converted to dc current through a series of diodes. you might not see this signal on a multimeter however on a occyliscope it is quite clear. the shift light has a small processing box which captures this unique signal and uses it as the Rpm signal. kind of like a g-tech (i think thats what the gizzmo is called.) so the answer to your Question is yes it is accurate and yes it is real time but you will need to set it up. as there is no rpm specific setting due to it can be used in anything from a car to a truck. you have a knob to set the lights brightness (and let me say u need the brightness knob because the high intensity blue leds in the shift light are F%$king bright) and another with rpm low/high so an accurate working tacho is required to set it up. They are simple and easy so even the most car illiterate person will find it hard to stuff up the installation. Plug, play, set & Forget its that simple.
I hope that answers yours and anyone elses questions about the shift light.
Kind regards
Dave
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
