Here is yet again more gear for sale:
Make a reasonable offer time all items listed in blue make a reasonable bid on
all items in red are firm prices!
Stock R33 fuel pressure regulator
Used
$20 $10
Genuine RB25DET water pump in box
good condition used
$50 $30
Bosch Wide band O2 sensor
used
$50 $40
Brand new Genuine Toyota Oil filter in box
suits 4A-GE/GZE, 3S-GTE, 2Y&3Y Engines
$10 $5
JAW Japan Shift light Brand new,With simple plug and play installation. Has been pulled
out of box to look at but has not been used
$100 (RRP $150) Sold
Starbo G-12 Turbo Timer
Used good condition.
$20
FET TB-508 Turbo timer
Used good condition
$20
Jaycar Digital Fuel Adjuster
Built from a jaycar kit. bult it myself works great.needs hand controller. dont need it now i have my power fc
$20
Small Nismo Sticker
$2
Brand new Genuine S13 Rear Silvia Bage
Still in box
$40 $20 (rrp $65-$80) Part # 99099-35F01
Brand New Genuine S13 Rear Nissan Badge
Stil in Packet
$20 $10 (rrp $30-$40) Part # 9909935F00
S13 SR20DET Steel intercoler pipe with adapter already fitted for blitz BOV
(from Stock cooler or arc upgraded intercooler to throttle body)
$40 $30
Autotecnica Horn button
Brand new
$5
All items now for individual sale
Buy all of this stuff plus all the gear from my other for sale post
http://www.skylinesaustralia.com/forums/Au...nd-t207193.html
and a stack of car audio gear including
Use all this stuff or sell it here or on other forum's or ebay it
to make a profit i dont care i just need all this suff gone.
Located in Sydney's Western Suburbs
All sales are cash only and you have to pick it up
$150 $100 $80 $50 FIRM for everything i want it gone including the audio gear
Kind regards
Dave
Edited by MR FLWLSS
  • Replies 49
Posted Images
Wide band O2 sensor, New oil filters, New subaru floor mats added
Toatal bargan price of $550 & $700 for the lot
Edited by MR FLWLSS
if you have anything you think i might be interested in im willing to swap the lot for something of interest to me :cool:
You sent me a PM, can you pm me a photo of the shift light out in the open.. I want to see the cover of it .. is it bling bling or black? what colour is the shift light itself?
price drop on total prices due to sale of hicas lock bar and digital speed meter.
Edited by MR FLWLSS
do u know if the flash light works of rpm according to the factory needle (which is a bit slow) or is it connected to the ecu rpm (realtime)?
actually its really cleaver its made so even a monkey can opperate it. it connects to power and thats it.
its rpm reference signal is the back emf that altinator produces. as the altinator rotates it creates pulses/bursts of energy, Because an altinator generates 3 phase ac current whitch is converted to dc current through a series of diodes. you might not see this signal on a multimeter however on a occyliscope it is quite clear. the shift light has a small processing box which captures this unique signal and uses it as the Rpm signal. kind of like a g-tech (i think thats what the gizzmo is called.) so the answer to your Question is yes it is accurate and yes it is real time but you will need to set it up. as there is no rpm specific setting due to it can be used in anything from a car to a truck. you have a knob to set the lights brightness (and let me say u need the brightness knob because the high intensity blue leds in the shift light are F%$king bright) and another with rpm low/high so an accurate working tacho is required to set it up. They are simple and easy so even the most car illiterate person will find it hard to stuff up the installation. Plug, play, set & Forget its that simple.
I hope that answers yours and anyone elses questions about the shift light.
Kind regards
Dave
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
