Project Hacker!!!!
By drifter17a · Posted
I think I follow re en-62 , I looked at rb26 and conical washer is after pressure washer. Would bit which is cut face pressure washer so flat surface face the nut? https://tinypic.host/image/IMG-4540.38gabk -
By soviet_merlin · Posted
What a statement to throw in there like that. If you do, could you make a build thread and share what it's like to own? Must be one of the old school coolest trucks out there. There's someone who owns one around here but I've always only seen it parked, and never driven. -
great really appreciate it re 3 I am worried as gear came off easy but no spinning etc. i reckon tuner has welded that 12 tab gear to the crank gear so crank position can be read by ecu re en-62 point 6 what do you mean? I am changing both tensioner and idler but looking to find torque setting as well -
At least you're now aware of the problem and can come up with a solution.
