well if you have 19s on a 33 it can be defectable as 18s are the biggest you can go. im pretty sure different size rolling diameter is illegal too. whatever state you in, check the on the state roads website for the rules and regs.
my moneys on defect. but hey... every mods pretty much a defect nowadays. :)
Edited by jake33
There shouldn't be a big difference in rolling diameter if you're using the correct tyres.
I'd say that they're illegal. I remember someone saying something about if you've got 225mm tyres all round, you can't go larger in the rear and not the fronts. They must stay the same width (all four 235, 205, etc), but if they came with 255's in the rear and 235's in the front, then you can go what ever you like in the rear and front (doesn't matter if they're not the same). I would say that it's the same for rim diameter. If your car came with 16's in the rear and 15's in the front then it would be legal. I'm not saying that this is the law, it could be complete bullshit (I think it is), just thinking out loud.
you'd be dumb to put it on an AWD
there was a topic bout a ferrari with 20" front and 22" back a while ago
unless you got adjustable suspension your car'll look like it just got anal probed
he has a gts-t...
if he got the right tyre profiles should sit evenly i think.
not sure if it helps, but a chrysler crossfire has bigger rear wheels from factory,
I think 18" front and 19" rear
I think the rule in NSW is that you can't go 1" bigger than factory and something to do with the width of the rim
Edited by Yo-Yo
Why not just go 18's all round? or 19's all round. Would probably be cheaper aswell.
Most ppl only do the 'smaller at the back, bigger at the front' So they can lower the car heaps and still be able to turn the front wheels yet fill out the guards.
But ive yet to see anyone do it with 18's as its too small to fill out the guards to the extent of rubbing.
i was just pondering the idea, i saw a few pics of a s15 with 18's on the front and 19's on the back and it looked really good. also theres some mags i like, except the 18" one only come in 8" width, but the 19"'s come in 8" and 9.5". so i was thinking maybe 18" by 8" on the front and 19" by 9.5" on the rear. just checking out all my options before i buy :D
Most people get smaller wheels out back because of cheaper tyre costs and larger wheels at front to clear their massive brakes. Usually see 17's out back and 18's up front.
If you get the right profile tyres, nothing/not much should happen to the speedo. Having 19's at the back and 18's up the front is no different to having 19's all round or 18's all round if you've got the right profile tyres.
It will depend what state you are in. Check with the transport department & get it in writing if you can, so you can proove your innocence when you get pulled up.
thats my advice.
There was an MR2 with 19's on the rear and 18's on the front. I think it was in one of the Video Option dvd's... Looked pretty good.
I doubt it's a legal requirement to have all wheels the same including the spare. Think of all the cars with space savers.... including Skylines...
In saying that. check first.
I reckon you could easily get away with it, as only 1 inch difference would be hard to spot by the authorities. My R33 has been running around on 19x10's and 20's for around 2 years, and yet to have a problem with the coppers..but i guess as with most things these days its the risk you take..
If you want to go 19's in the rear and 18's up front, just do it. Chances are you'll probably get dicked for having tyres that are too wide or you increased your track by more than the legal limit anyway.
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
