Importing Track Car
thinking of importing a s13, s14 or r32 skyline for track use only.
where/who are the ppl to ask who can bring a car over and give definate prices.
so if you know anyone or you do it yourself, please let me know.
thanks
We import race only cars for people reasonably often so we can certainly help you too ... please email me at [email protected] with details of what you are after so I can see what's around for you now. Also please confirm that you have a level 3 CAMS licence (national level) and can provide some evidence of recent motorsport activity in order to satisfy the DOTARS requirements for getting an import approval - if you don't meet the requirements then you need to find someone else who can import the car for you or look at getting a 1988 or older vehicle.
thanks
Why not look for a car that is available locally? You get the huge benefit of being able to see the thing yourself, know that it is log booked (If required), comliant to all of CAMS nonsense (If required) & best of all know what lap times it is capable of at a local circuit.
Just about every race car I have ever seen is "for sale" - mostly because the drivers always have an eye on their next prospective purchase...
jspec. i threw cams a question regarding C3 cams license's and drift car importaton. and they said that if the car is being used for drifting then the importers are wrong. he said that L2S license's are all thats required to import a drift car. because drifters are competing under the L2S license.
how true is this statement.
i will pm u just incase u dont read this.
that's all well and good, but it's not up to CAMS, it's up to DOTARS. they issue the VIA. so I would be asking them as what they tell you is the only answer that matters.
i will ask them no harm done there.
if they need a C3 i import through someone who has a C3 and take it off their hands after it arrives in australia, and goes thru its stuff.
obviously it would have to be retransfered into my name.
CAMS will advise you of what licence is required to drive a car in a certain class not what is required to import that car ... DOTARS are the ones who issue import approvals and they demand a level 3 licence for any motorsport import because it's not simple to get this level licence like it is to get a level 2, and that serves their purpose well to ensure that you are serious and active in motorsport.
Call DOTARS on 1800 815 272 and ask them, and by all means if someone tells you that you can import a drift car with only a level 2 licence then make sure you get it in writing too!
Not to throw a spanner in the works, but I have first hand knowledge of a car that recieved import approval for race use with NO CAMS licence at all. Car is now in Australia and under-going upgrades to run in AASA sanctioned events at QR and later at Lakeside.
Obviously there are some exceptions in certain cases because it's up to DOTARS who they approve in the end, however their official position is a level 3 licence so I would not expect anyone to be approved without that unless there was some very unusual circumstances and/or some mistake on the part of DOTARS. I didn't want to mention that there was even a small chance to get a race import without a level 3 licence because the chances are so slim that it's not even worth considering.
Before everyone starts saying that they should approve drift race imports without a level 3 licence because you don't need that to complete in drifting, I should advise that this arguement will not get you past DOTARS at all otherwise people would just import any car they choose and say it was for drifting. DOTARS will insist on a level 3 licence from everyone for any race import in 99.9% of cases.
True enough, but it "can" be done if you're keen enough.
No mistakes were made, however the time was taken to explain carefully and politely. Dealing with DOTARS is like dealing with the police. You give them attitude, you're screwed. Treat them politely, explain yourself carefully and validate your reasoning and they'll treat you the same.
But, don't EXPECT it to work. Sometimes people have a bad day at work and no amount of politeness can convince them you're worthy :D
Naturally J-Spec can't offer advice that isn't in the rules which is also why I haven't offered any more info then the fact that it has been achieved legally, through DOTARS without a L3 CAMS licence.
  • 3 weeks later...
yes that is no problem. you can go from registered car to race registered/race only car. but you cannot import a car for race use then change your mind the other way.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
