If u want to respray a car a different color, how far do you have to sand down the existing paint?
Some people have told me just sand it till the clear coat and pearl is gone.
Some ppl have said sand till the paint isn't shiny
Any then some spray guy, who i think is just trying to make more money, says u need to sand all the way down so u can primer bear metal.
What is true or what is shit? Any done a repsray be4?
https://www.sau.com.au/forums/topic/20771-respraying-car/
  • Replies 82
well if u want a proper respray u sand down to bare metal but u can get a way with just sanding down till u cut into the original paint. all comes down to how much ur willing to spend and how fussed u are about things...have fun!! wat colour are u spraying to by the way??
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-435816
the spray guy is taking about a properly done job. It depends on what sort of result your after.
The guy that did mine, (for the previous owner), only went down under the clear and pearl. Now in the sun you can see where the preparation was bodgy i.e. scratch marks in the filler/primer. Remember, if it looks half decent in just primer, it'll look like shit when its painted. It needs to be 100% effort in preparation to look 100% when its painted.
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-435820
thanks dudez,
I'm spraying it in the Evo VI white. Not sure if its just the same as the normal lancer white. Not the pearl version though.
Well he gave me an alright price. All the work for $2k, but u kno, spent so much already so i told him i'll prepare it for him myself.
So....it'll look like shit if i sand it huh?
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-435831
"No, just keep using finer garades of sand paper till you cant see or feel any defects."
Black32, When u said this, do u mean sanding it all the way till bare metal or doesn't reali matter if u have finer paper.
Also does anyone kno which type to use? I used the wet/dry type for a while but it didn't last long.
So i used this Yellow, ultra-fine 3M something like 255 or something. And it doens't die off at all. I think its meant to be for wood, but like, all the powder just falls off. Sand paper still like new. God or Bad?
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-435862
going through the exact same thing right now, i actually have a few mates that do respraying, soo this is the info that i got!
to sand back the car etc, i used heavy duty scotch brites.... sounds funny but the benifit of using these over say 600 or 800 wet/dry is that it doesn't actually cut into the paint like sandpaper!! thus not having the trouble of it digging in any spots due to uneven pressure, plus gets into fiddly bits easier!!!
this is only going to be good if the currunt paint job is good-ish quality!!! just gotta take it down far enough to really dull --> hardly any reflection!!!!
I've gotta bit more wqork on mine fixing dents etc, plus a custom body kit i made myself!!! big job!
good luck with it!!! post or pm for more info.
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-436549
true,
but theres that thing of getting exactly what you want, and the pleasure of seeing your own hard work in it!!!
or am i getting sentimental :(
i've spent 2.5 months working on it -- lost licence, sob!
so what better time to do it!
if your going to do it yourself-- slow and steady is the key!
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-436619
Craved U lost u're licence? hehe same here, started on friday 3 months, so no big rush for me either.
Yea thanks for the info guyz, i kinda learnt thru trial and error.
I didn't use water, man the paper just died on me almost immediatly and scrathed, but luckily didn't do much yet so could be fixed with water now and fine paper later.
So what is this scoth brites thingie u'r talking about? And sand paper grades, is it higher the number the finer? Thats what i thought, when u said 600-800, i'm thinking this is realli fine paper, man...no hope at all. Took me a whole afternoon just tocut thru the clear coat and arm was dead. So going with coarse stuff + water then going for the wet/dry fine paper laterz.
Good idea or ?
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-437917
Craved, are u sanding down a R33?
have u got alll the windows off? if so, and dindnt do u'rself..how much it cost? someone quoted me $85 all four. haven't called anyone else, but it seems good enough isn;t it to take out the windows for $85/?
Yea and choas, thats what i wanna do, just sand it down enough to cut thru paint. like till its all dull n shit, but alot of people are still telling me that sand it down to bare metal. fa^rk man.... i realli coudln't be f ucked....its alrite isn't it???? just sand it down to dull paint?
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-437922
well all i can say is 95% of doin a good job is in the prep...the rest is spraying itself. i personally wouldnt do it myself cause i know how bloody hard it is to get perfect surfaces. u might think it looks all smooth and even when its all dulled out but even the slightest imperfection where u pressed just that bit too hard with ur finger will show up when sprayed. a friends mate decided to do the same thing and prep it himself....took it to his cuz/uncle to spray and they checked under the light to see if it was preped proper and laughed at him and told him to do it again....lol.
not saying u guys cant do it...im sure u can...just sayin that there is more involved than just cutting it back. AZN_ROMEO.....no offence but it sounds like u dont know wat ur doin as respraying a whole car is a big job and as REDLINE said it might end up costin u more in the end. might be good if u go and talk to the spray guy for tips and practice on something small first to get the gist of things.
as for goin with the coarse stuff under 600 i wouldnt recomend it as ull get hella scratches everywhere that would be hard to get out with the fine stuff. might save u some time at the start but will break ur balls in the end.:):D
i might sound like a perfectionist but i hate seeing nice cars with bodgy warped surfaces like mine...haha:D:D keep us posted as i want to respray mine in the future...good lucks
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-437957
yea u'r right tho....i don't have any idea what i'm doing.
but slowly learning. This car has been pissin me off for too long man. seriuosli. so couldn't be fa^rked sometimes. The thing is, is that i'm not after a full show car look, just something that looks nice. Besides the spray painter is going to fix up anything i dind't complete...haha or f arked up...
if u ask me why i do it? coz it saves a shit load of cash. plus i kno couple if my freinds had their car resprayed....not the perfect bare metal prep. just rub down, clean, prim n spary over. and...the result is pretti good.
If anything fu cks up..like totally stuffed up uneven sanding. then out comes the paint stripper. lol. I've got three months times to do anyways (licence). so time not realli worried about and wounld'nt mind doing it, just that it;ll take 5 times as long maybe more.....
but thanks for the tips tho B1... and when u told me to ask the painter for tips....well thats why i started this thread..Lol.... for tips, ideas and methods but yea thanks anyways.
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-437965
Guest RedLineGTR
Originally posted by Craved
true,
or am i getting sentimental :)
yah thats true...if your gonna do it yourself...pop down to a shop that does the type of work and get some advice about what to do.
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-438088
yea...got some advice today from painter.
gave some instructions but coming down in the week to double check.
Anyone had their cars resprayed? I'm thinking about engine bay too...since the engine is going to come out. Is there too much shit to remove and mask up for engine bay spray?
https://www.sau.com.au/forums/topic/20771-respraying-car/#findComment-438266
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
