Average Time On The Boat?
We find that most ships take around 12-14 days roughly, with the occasional one going up to 16-17 days but not usually any longer ... if you tell us the name of the ship and your destination port then I can give you a more exact date?
Your car won’t necessarily get on the first ship your agent says, other larger clients always have priority. There are many problems which may affect the service, berth congestion in Japan and Australia can sometimes cause delays (although both Japanese & Australian ports are pretty good). Big ports in developed countries have 'windows' in which each vessel is given a certain time to arrive by and they have 'guaranteed' reserved birthing space. If ships miss their 'window' to berth at a port they get placed to the back of the cue. There are various other random delays that can cause significant delay also. If the vessel calls into smaller countries along the way, these are usually the places where delays occur. But on a route from Japan to Australia you shouldn’t really encounter many problems and vessels tend to stick to the schedule most the time. I'm ship planner at ANL container lines and deal with delays everyday (mostly from ships visiting smaller pacific islands and sub-standard stevedoring activities that cause a major pain in the ass.)
recently a mate just imported a ae111 sprinter.
took 2 months.
plus customs charged him extra money to go over it in a quarantine procedure. which was a 'random' thing
that was an extra 3wks
Edited by r33cruiser
well the car got on the boat he said it would.
Very happy with mark hocking, BTW. i have about 200 pictures of everthing - the car inside and out, it being driven to the boat, it being drien ON the boat, it sitting in the park space on the boat, it being tied down, all the shit being hidden (log books, flares, timer, speed meter etc).
Ship docks at brisbane 15th march, left japan today (27th feb) so really thats about 2 1/2 weeks or so. Decent!
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
