Phillip Island - Sat 29 March - Club C/ship Rnd 2
Entries and Supp Regs are now available for PI.
Entries - http://www.wrx.com.au/motorsport/PI_WRX_29_Mar_08_entry.pdf
Supp Regs - http://www.wrx.com.au/motorsport/PI_WRX_29..._08_supregs.pdf
Unfortunately there will be no driver training at Phillip Island.
Anyone wishing to help out on the day, please email your intentions to [email protected]
***ENRTY LIST - http://www.wrx.com.au/forum/viewtopic.php?f=23&t=47871
  • Replies 103
Posted Images
Ok Stig, if you want a steer then speak up soon. I think i will only be sourcing 2nd hand tyres as the respray and some other work on the car will leave things pretty lean...plus a mate from school has decided to get into cars again and wants my car because it blew the doors off another friends Lotus 340R :P
Ok Stig, if you want a steer then speak up soon. I think i will only be sourcing 2nd hand tyres as the respray and some other work on the car will leave things pretty lean...plus a mate from school has decided to get into cars again and wants my car because it blew the doors off another friends Lotus 340R :)
Faxing my form in tomorrow...
I wonder if I can double enter so I can drive the silver bullet??
Obviously have to be in a different group....
Just tag a session in one anothers cars.
Will have to see what Adam is doing. Not sure if he plans on doing PI with his car, at all, as is, with new Teins, with my Teins etc etc. Adam?
I'm writing a movie.
"10 things i hate about Snowy"
Who wants to help.
Ooooh me..me...me *sticks hand up*
Looks like the GTR group is going to be full of Racepace tuned R's....and Matt....and lil old me :(
Whats this about the HSV club...have they joined the WRX trackdays as well?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
