im going to try a different fuel i think
ive just filled up with Mobil Synergy 8000 or whatever it is, we will see how that goes
also, cos its been so hot lately, ive been using my A/C heaps
im going to see if out of a tank i dont use it at all and see what difference that makes
"Yah bro!" :)
Its mm of mercury...
Trust
Me
I have a HKS Boost Gauge
The pointer goes only up to where I have circled, which I believe is +0.7 Bar = 10.1 Psi.
Just help me clarify this cuz Iam interested to know...
Thanks!
Also, don't bother saying how many KMs you get to a tank. The best way to work it out is:
1. Fill up to a full tank
2. Reset trip meter
3. Drive
4. Fill up, note how many litres it takes
5. Do this calc: Litres divided by KMs ... then times that figure by 100 = Litres per 100 KMs
The reason this is a better comparison is that one mans "empty" is different to another persons. For example, I normally get 320kms out of a tank... but I never take mine to RIGHT on the E mark, and I put 42-46L in it.... so around 13 - 14 L per 100kms, which is around normal for a mildly modified GTR IMO.
yeah thats why i said removing the restrictor makes you run 14.7 psi
not saying that is a good idea
what im saying is that the gauge is in mmHG not bar
7 mmHg = 1 bar
May i ask, where is the restrictor that you remove to get full boost?
  • 1 year later...
my 32gtr is pullin 400km's for full tank. all i had done was injectors cleaned, changed air filters, o2's,
i give it a fair bit of push around suburbs.
but yer my injector is now leaking out fuel i assume this time round i wont be gettin 400k's.. what is it i need to replace .. O-rings for it? and is it hard to replace?
i just got a power fc installed + car tuned.
driving sensibly im now getting around 420 to a full tank round town.
i've been giving it a hard time this tank and it looks like it will hopefully still be around the 320 - 350 mark.
car is almost stock - 222rwkw @ 12 psi.
hope this helps.
also, check your comp - is it standard? my old cpu was the main cause of my previous poor economy (around 300 to a full tank barely hitting boost).
Edited by KR4-GTR
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
