Need to clean out shed!
Have two new projects and no room!
Most parts are pick up only!
Located in Melton Victoria
Please dont ask for parts not listed!
Click on links for photos, or they are able to be emailed on request
180SX
Exterior
Fuel tank including sender (1/4 tank of fuel) $100
wiper garnish $30
mud flaps (only have 3) $7 each
passenger Quarter Window garnish $10
quarter window metal frames?? $10 each
Passenger Tail light $70
Rear Tail light Garnish $30
Drivers Side Mirror $75
Bonnet stand $15
Rear number plate lights and bracket $30
A pillar trim $20 each
Interior
Drivers Door trim, damaged in top right corner $40 Drivers / Drivers Damage
Passenger A pillar trim $30
Dash intrusion bar $40
Center Air Vents $50
Passenger door window trim $15
Passenger door trim $10
Drivers door window trim $15
Front seats $100 pair
Center Console (complete) $80
Steering column with stock steering wheel (not separating) $offers
Dash $80 - crack starting to emerge, no holes or tears.... suit retrim
Floor carpet $30
Accelerator pedal box, including cable $20
Digital climate control with full loom $220
Suspension
Rear Cradle (non hicas model) $150
Rear Upper control arms $40 each
Rear sway bar with links $50
Rear Calipers $80
R32GTS-T
Make an Offer on all parts.. had them too long!
Nissan Skyline R32 GTR Drivers Seatbelt $50
Nissan Skyline R32 GTS-T Rear Passenger Trim $20
Nissan Skyline R32 GTS-T Rear Sway Bar $10
Nissan Skyline R32 GTS-T Rear Upper Control Arms $20 each
Nissan Skyline R32 GTS-T Front Passengers Upper Control Arm $20
Nissan Skyline R32 GTS-T Rear Cradle / Sub frame $150
Nissan Skyline R32 GTS-T Petrol cap and panel $10
Nissan Skyline R32 GTS-T Air con / Heater boxs and motors $5
Nissan Skyline R32 GTS-T Loom (cut up and not complete, suit someone looking for particular part, or willing to strip copper out) $20
R31 Series 3
Rear Seats Blue $30
Parcel Shelf $5
Steering Wheel $20
Center console Blue $10
Door Cars Blue $40 or $10 each
Have the entire interior available, minus the front seats. (roof to floor, front window to rear window) $100 the lot or prices above
Photos pending as for some reason I can not add photos anymore??
Edited by CrazY_J
https://www.sau.com.au/forums/topic/207801-huge-shed-clean-out/
  • 3 weeks later...
  • 1 month later...
180SX
Exterior
wiper garnish $30
Bonnet stand $15
Interior
Floor carpet $30
Suspension
Rear Calipers $80
R32GTS-T
R31 Series 3
Rear Seats Blue $30
Parcel Shelf $5
Steering Wheel $20
If you still have the fuel tank i'd like it. It is in working condition and has no rust? Also what year model did it come from?
i'm situated on the sunshine coast QLD. Where you at?
cheers, get back to me
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
