Cruise Tonight March 15th: Mandurah -> Perth -> Freo
Magic
 Share
  • Replies 66
Well we're leaving Mandurah at 9.30, takes about 20mins to get to Baldivis shops (if you keep the speed), should leave Baldivis shops by around 10.05-10.10.
So to answer your question, should be there around 10.35 or so?
I think mattxwa with the white 33 is meeting us at carousel too, maybe arrange to follow together to carousel or something?
joondalup sheeshh.
For those meeting us at one of the regroup points. I'll post the ETA's for each regroup point on the first post so you have a rough idea.
But If you'd like me to pm you my mobile # let me know and you can give me a call on the nite and I'll update how far away we are from the stop point etc. :blink:
Edited by Magic
I've also got some people meeting at the carousel also. Expect us to be there 10.30-11.00, otherwise just enjoy the driver down to Mandurah
Clint.
EPIC FAIL :P:(
doing that clutch has turned out to be really difficult, gotta remove a million things, i wont have it done by tonight,
I dont wanna sound like a bum but does anyone feel up for a nav?? I know its a bit late notice n i'm sorry but if anyone lives NOR, and wants some random guy to nav for em' let me know :P *gets on knees n begs*
Thanks guys
Edited by AMMERTY
yep, alright i'm coming :D we can grab maps at carousel?
andrew
anyone here NoR want to meet somewhere beforehand and head to carousel together?
i'm in mirrabooka
Edited by fei-sti_rex
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
